X-pipe gaskets
  • retterath
  • retterath's Avatar Topic Author
X-pipe gaskets
02 Jan 2016 13:01
#705320
I've got a Murray X-pipe on a 1980 KZ1000 ltd, and have been trying to track down an air leak. It occurred to me that when I replaced the pipe after cleaning and painting it, there weren't any gaskets or seals between the head and pipe. Should there be? Copper washers or something?
  • Kwaker2000
  • Kwaker2000's Avatar
Re: X-pipe gaskets
02 Jan 2016 14:42
#705329
you are missing gaskets for sure
  • mopguy
  • mopguy's Avatar
Re: X-pipe gaskets
02 Jan 2016 14:44 - 02 Jan 2016 14:47
#705330
I am not familiar with your exhaust, but with any exhaust you are going to need washers, usually they are made of copper and you also need header shims to get a snug fit and have no leaks.
Last edit: 02 Jan 2016 14:47 by mopguy.
  • z1kzonly
  • z1kzonly's Avatar
Re: X-pipe gaskets
02 Jan 2016 15:13
#705332
retterath wrote: I've got a Murray X-pipe on a 1980 KZ1000 ltd, and have been trying to track down an air leak. It occurred to me that when I replaced the pipe after cleaning and painting it, there weren't any gaskets or seals between the head and pipe. Should there be? Copper washers or something?
Sorry! You must remove it now! And replace it with another exhaust.
Then ship the X-pipe to me immediately .
This will fix your leak. :lol:
  • PaintWorkz
  • PaintWorkz's Avatar
Re: X-pipe gaskets
03 Jan 2016 05:01
#705391
Retterath......I will trade you a new MAC for that old Murray X pipe! But you still need to install new copper gaskets to prevent leaks. The copper gaskets are hollow tube rings that crush to seal pipes that do not align perfectly to the head port. Also some Murray race pipes had thin aluminum spacer rings that slipped onto the ends of the head pipes to center them in the ports. If these are missing these it might be difficult to get them to seal because the stack up and alignment will not be correct.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • retterath
Re: X-pipe gaskets
03 Jan 2016 09:27
#705425
I 'm reminded of the time I took some rare and desirable big block ford heads to have small cracks repaired, "These are not repairable, but i"ll give you $500 for them."
Will get a good look in there in a bit. You know, It ran great until i removed and replaced the exhaust.
  • pete greek1
  • pete greek1's Avatar
Re: X-pipe gaskets
03 Jan 2016 09:37 - 03 Jan 2016 09:40
#705426
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationGaskets , lock washers & nuts
Pete
Last edit: 03 Jan 2016 09:40 by pete greek1.
  • pete greek1
Re: X-pipe gaskets
03 Jan 2016 09:47 - 03 Jan 2016 09:48
#705427
The exhaust gaskets are hollow copper & get crushed when you tighten down the exhaust, & should be replaced with new ones whenever you replace your exhaust system
use a small screwdriver or pick to make sure the old gaskets are still not in there, as they turn black over time & it's hard to notice them still in your head
Pete
Last edit: 03 Jan 2016 09:48 by pete greek1.
  • DFIGPZ
  • DFIGPZ's Avatar
Re: X-pipe gaskets
03 Jan 2016 10:16
#705432
Stock Replacement.
1984 750 Turbo
