oil filter change
  • Kwaker2000
  • Kwaker2000's Avatar Topic Author
oil filter change
29 Dec 2015 10:07 - 29 Dec 2015 10:08
#704770
hi folks just changed my oil and filter on my csr1000 ,but did it on center stand ,pulled drain plug first then oil filter ,
replaced both then went to fill oil up put 3 liters in ran engine oil light was on for a moment then it went out ,let tick over a few mins ,stopped engine looked in sight glass and its on top mark ,have i put too mutch oil in ,or should i have drained oil on side stand
Attachment 20151229_181202.jpg not found
Attachment 20151229_181208.jpg not found
the reading was done with bike on center stand
Last edit: 29 Dec 2015 10:08 by Kwaker2000.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: oil filter change
29 Dec 2015 10:09
#704771
Looks fine from where Im sitting Dave :)
The following user(s) said Thank You: Kwaker2000
  • Kwaker2000
29 Dec 2015 10:12
#704773
yes but i only put 3 liters in
  • Kwaker2000
29 Dec 2015 10:19
#704775
is this oil alright to use on a csr1000
Attachment 20151228_124746.jpg not found
Attachment 20151228_124820.jpg not found
29 Dec 2015 10:30 - 29 Dec 2015 10:31
#704777
You changed the oil correctly, used the correct oil, and did not overfill it. You can add more oil until it rises to the top of the site glass, and that will bring the total amount of oil closer to 3500cc. On my KZ650 the recommended amount (3500cc) brings it to the very top of the site glass. Ed
Last edit: 29 Dec 2015 10:31 by 650ed.
  • bountyhunter
  • bountyhunter's Avatar
29 Dec 2015 10:50
#704785
Kwaker2000 wrote: hi folks just changed my oil and filter on my csr1000 ,but did it on center stand ,pulled drain plug first then oil filter ,
You get a better drain on the center stand. But if you are really fanatical about getting ALL the old oil out, you can take out the spark plugs and use the kickstarter to turn the engine over which will pump out the oil in the filter and inside the engine. I think that's overkill.
As for the sight glass: looks fine, but with new filter you need to run it maybe 15 minutes or more and get the filter fully saturated, then let it sit for an hour to let it fully drain down.
The following user(s) said Thank You: Kwaker2000, 750Kruzer
  • Kwaker2000
29 Dec 2015 12:42
#704797
this is what i like about you guys on here your very helpful ,thanks and a very happy holiday to you all and a great new year B)
