Best black paint for Generator cover? 1982 GPz750
  • Madtrout
  • Madtrout's Avatar Topic Author
27 Dec 2015 10:18
#704542
Can anyone reccomend a glossy black paint for the generator and pickup covers for my 1982 GPz750? I was thinking of going with the VHT glossy engine enamel for its high temp qualities.
Also, the Kawasaki emblems that attach to these covers are rather worn and I'd like to replace. They seem to unavailable from the regular parts suppliers. Anyone have an idea where to get new ones? Thanks, Mark
  • Nessism
  • Nessism's Avatar
Re: Best black paint for Generator cover? 1982 GPz750
27 Dec 2015 10:25
#704544
I used VHT Satin Black and it was quite glossy, more so than the stock Kawasaki paint. The VHT is very brittle paint and it will crack and chip under the screw heads. I used the stuff but can't recommend it for this reason. Maybe try PJ1 paint instead?
The following user(s) said Thank You: Madtrout
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
27 Dec 2015 10:55
#704549
PJ1 and then bake it.
[IMG
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • DFIGPZ
  • DFIGPZ's Avatar
27 Dec 2015 10:58
#704550
on my 750 Turbo Restorations I always have engine covers powder coated they hold up and look great for years.
1984 750 Turbo
  • Madtrout
27 Dec 2015 11:27
#704553
Thanks for all of your suggestions. All the best, Mark
  • baldy110
  • baldy110's Avatar
29 Dec 2015 08:35
#704754
I use the two part black POR-15 paint. That stuff holds up really well and looks great.
[IMG
[IMG
  • TexasKZ
  • TexasKZ's Avatar
29 Dec 2015 08:56
#704758
  • baldy110
  • baldy110's Avatar
29 Dec 2015 10:19
#704774
  • pete greek1
  • pete greek1's Avatar
29 Dec 2015 10:35
#704780
baldy110 wrote: No I use this.
www.por15.com/2K-Urethane_p_123.html
Baldy, it says to use over primed or painted area
what primer did you use?
& it doesn't say what heat temp it can withstand
Pete
  • Nessism
  • Nessism's Avatar
29 Dec 2015 13:15
#704802
I used Por-15 Engine Enamel on a Suzuki GS1000 engine (silver) and it turned brown quite quickly. The black should be better but I'm leary.
  • baldy110
  • baldy110's Avatar
30 Dec 2015 13:19
#704935
I don't use any primer, I sandblast the part, clean it up then treat with por 15 metal prep. I then heat in an oven then remove and spray the paint on. Very durable stuff and keeps the shine.
