billet cam plugs J-model
- z1wiz
27 Dec 2015 07:10
Does anybody know where I can buy the billet aluminum cam end plugs for a J-model motor?
I know I have seen these for sale but can't remember where.
Thanks,
Russ
Thanks,
Russ
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
- daveo
Re: billet cam plugs J-model
27 Dec 2015 07:25
z1wiz wrote: Does anybody know where I can buy the billet aluminum cam end plugs for a J-model motor?
Thanks,
Russ
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: z1wiz
- z1wiz
27 Dec 2015 07:50
Thanks daveo
Exactly what I remember except where.
Russ
Russ
27 Dec 2015 08:08
No eBay APP ID and/or Cert ID defined in Kunena configurationAre the J-model plugs different from the earlier plugs? Reason for asking is there is another guy selling aluminum cam plugs but they list as applicable for '80 and before bikes...
- floivanus
27 Dec 2015 08:18
73-80 are solid, no bolt hole in the end plug, 81 and up have a bolt that goes thru the end plug
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- baldy110
29 Dec 2015 08:42
And when you install them do not use that silly strip of o-ring they comes with them. Fill the o-ring gap with RTV then install.
The following user(s) said Thank You: PLUMMEN
01 Jan 2016 11:41
In case anybody else is interested, American Classix carries them.
americanclassix.com/kawa_improvements.html
