Staking Oil Pump Screws?
  • Madtrout
  • Madtrout's Avatar Topic Author
24 Dec 2015 16:20 - 24 Dec 2015 16:45
#704250
Does anyone know the correct procedure for staking the oil pump screws on a GPZ750 engine? Specifically where and how hard to punch the head? Would blue Loctite be enough? Thanks, Mark
Last edit: 24 Dec 2015 16:45 by Madtrout.
  • Nessism
  • Nessism's Avatar
Re: Staking Oil Pump Screws?
24 Dec 2015 18:07
#704265
Madtrout wrote: Does anyone know the correct procedure for staking the oil pump screws on a GPZ750 engine? Specifically where and how hard to punch the head? Would blue Loctite be enough? Thanks, Mark
I use Three Bond Green threadlock on those (green is medium strength and high temp). I also staked them using a pointed punch - strike them near where they were struck previously.
The following user(s) said Thank You: Madtrout
