1982 GPz750 Does a bolt go here?
- Madtrout
24 Dec 2015 07:55 - 24 Dec 2015 07:56
Just freshening up the oil pan before I start reassembly of the engine and I notice a hole on the bottom that leads to the Oil relief valve. Should there be a bolt in this hole? I didn't notice one on disassembly. Thanks, Mark
Attachment GPZ_750OIlPANcopy.jpg not found
Last edit: 24 Dec 2015 07:56 by Madtrout.
- scubaanders
Re: Re:1982 GPz750 Does a bolt go here?
24 Dec 2015 08:07
That bolt hole is for the original exhaust.
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: Madtrout
24 Dec 2015 08:35
Does it go all the way through?
24 Dec 2015 08:58scubaanders wrote: That bolt hole is for the original exhaust.
/A
This
It's a blind hole, shouldn't go though.
- Madtrout
24 Dec 2015 09:25 - 24 Dec 2015 09:26
Ah you are right, It does not go through. I do have a Supertrapp exhaust, so perhaps it was a mounting point for the original exhaust. Thanks for all your help, Mark
Last edit: 24 Dec 2015 09:26 by Madtrout.
24 Dec 2015 10:05 - 24 Dec 2015 10:07
Last edit: 24 Dec 2015 10:07 by martin_csr.
