Engine Work
  • Junkyard Dog
  • Junkyard Dog's Avatar Topic Author
Engine Work
18 Dec 2015 10:00
#703505
Who does proper engine and head work and knows Z1's?
1975 Z1, 4:1 Kerker, Bought in 1981, Got it running after sitting 15 years.
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Engine Work
18 Dec 2015 11:35
#703518
where are you located at ? I am in Maryland
1984 750 Turbo
  • z1kzonly
  • z1kzonly's Avatar
Re: Engine Work
18 Dec 2015 13:02
#703528
[quote="Junkyard Dog"
Hi Junkyard Dog!, this is the infamous "Jim Oddy" NHRA Hall of Famer! AA/GS Nostalgia Car Last year at Norwalk, OH.
Just a little side note.
  • z1kzonly
  • z1kzonly's Avatar
Re: Engine Work
18 Dec 2015 13:12
#703530
Just 1 more, Fast is fast, Drag racing is cool Bikes or Cars.
Last one! Sorry to high jack thread. This is what I do.
Check em out on the East Coast thru Michigan
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Engine Work
19 Dec 2015 04:10
#703597
PM sent with 3 referrals
The following user(s) said Thank You: Junkyard Dog
  • Junkyard Dog
Re: Engine Work
19 Dec 2015 04:37
#703598
I'm in Rhode Island
  • Junkyard Dog
Re: Engine Work
19 Dec 2015 04:43
#703599
Attachment IMG_2960.jpg not found
  • Junkyard Dog
Re: Engine Work
19 Dec 2015 05:46
#703611
Just some background...and I'm totally open and encourage suggestions. My bike has been sitting a long time. I recently cleaned the carbs and now in the process of adjusting the little buggers to get the bike to idle, ect. I have clean fuel and new manifolds. I've done a quick measure on a couple of valve clearances and I need to adjust them. Should I get the carbs set first before I mess with the head or maybe just send the head and out for proper evaluation? I'm wondering if I'll be chasing perceived carb issues caused by potential bad valve settings? Way back when, I had a guy do a valve job. I have never been confident he did a good job. I basically want the engine to run properly and accomplish that in a sensible order.
  • TexasKZ
  • TexasKZ's Avatar
Re: Engine Work
19 Dec 2015 06:35
#703621
Carb adjustment should come last. Valve adjustment and head work will change the vacuum signal to the carbs, necessitating adjustment.
  • zukdave
  • zukdave's Avatar
Re: Engine Work
19 Dec 2015 07:10
#703629
Pm riturbo he should be able to lead you to a local shop.
Tell him I sent you he'll help.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Junkyard Dog
Re: Engine Work
19 Dec 2015 11:58
#703655
That makes sense...thanks.
  • Junkyard Dog
Re: Engine Work
19 Dec 2015 11:59
#703656
Thanks..will do.
