NOS Gasket, surface rust
  • dom2570
  • dom2570's Avatar Topic Author
13 Dec 2015 08:02
#702948
I managed to win a NOS, unopened, top end rebuild gasket set for $17.
When it showed up, first thing I noticed was that the copper exhaust gaskets had oxidized a bit. No big deal, but then I noticed a bit of surface rust on the head gasket. Nothing huge, a bit of lime away should take it right off.
The big question is, can I still use it, or is it not worth the risk?
Whip it like a mule!
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: NOS Gasket, surface rust
13 Dec 2015 08:59
#702961
Better head gasket description would help.
Example for me, I use one piece copper head gasket and when I take motor apart to reuse the gasket I heat it up in the oven and anneal it . Then clean it with scotchbrite to be ready to reinstall .
Is your gasket just a composite gasket with a little metal at the bores ??? A little oxidation can carefully be cleaned from
the metal with no ill effects
As always pictures would help
Dave B) B) B)
The following user(s) said Thank You: PLUMMEN
  • Nessism
  • Nessism's Avatar
13 Dec 2015 09:52 - 13 Dec 2015 09:53
#702967
What bike is this for?
As far as I understand Kawasaki (Japan) didn't sell gasket kits, but the US distributer had an accessory gasket kit they sourced local (not the same gaskets as Japan sells).
I bought a NOS kit for my 750E and the gaskets were all dried out and brittle as glass. Wound up sending it back. Discoloration on the copper gaskets is the least of your troubles.
Last edit: 13 Dec 2015 09:53 by Nessism.
  • dom2570
Re: Re:NOS Gasket, surface rust
13 Dec 2015 10:59
#702971
I'll post some pictures tonight. It is for an 82, 750H.
All the rubber bits are fine, base and valve gaskets are not brittle. If the head gasket is ruined, I can't complain. $17 for new rubber bits is well worth it.
  • dom2570
13 Dec 2015 11:00
#702973
I'll get better pictures when I'm home from work.
  • Nessism
  • Nessism's Avatar
13 Dec 2015 11:08
#702978
Okay, my bad. For some reason I was thinking OEM gaskets.
That's an old aftermarket Vesrah kit. Never the best quality and now (possibly) hard and brittle.
Those copper rings are exhaust gaskets. No worry with them turning dark or even green.
  • Moderator
  • Moderator
13 Dec 2015 11:52
#702981
Nessism wrote: Okay, my bad. For some reason I was thinking OEM gaskets.
Agree with above.
I would buy new Cometic brand gaskets for what ever you are short
Dave B) B) B)
  • bountyhunter
  • bountyhunter's Avatar
13 Dec 2015 12:58
#702995
Nessism wrote: What bike is this for?
I got a set that looked OK (Athena?) but all the "green" gaskets hardened and disintegrated after heating up. I had to tear the engine completely down and replace them all. Obviously I will never again use suspect gaskets.
  • dom2570
Re: Re:Re:NOS Gasket, surface rust
15 Dec 2015 11:20
#703207
Agree with above.
Dave B) B) B)
Anyone have a link to a good supplier of these?
  • Nessism
  • Nessism's Avatar
15 Dec 2015 12:27
#703212
I recommend OEM Kawasaki gaskets. Tried and true. You can find good deal on ebay or purchase from Partzilla, Bike Bandit, local dealership source, etc.
If you pull the head be sure to pull the cylinder off too and replace the base gasket and associated seals. It's very poor planning to pull the head but not replace the base gasket at the same time.
