82 KZ1100 newb question
  • xxgrizzlybearxx
  • xxgrizzlybearxx's Avatar Topic Author
06 Dec 2015 19:47
#702222
Hello guys. I defer to your knowledge. I have just picked up a great garage find that's been stored for years. I've put some work in but just want to get it all together before I try ti fire her up.
I have a question I'm at a loss. I know I need to get a Clymers soon but haven't gotten to it just yet. In the pic, there's a threaded hole to the crank area.(not the missing crank vent hose above the tranny I already know I'll need to filter that. Is this for a breather hose? I can't see where it would connect to on the moto/carb unless it's just missing. Everything looks pretty complete short of the starter solenoid and that hose. I HAVE seen a few KZ1100 that there's just a bolt in there, and some where there's a hose running out of it and up near the carb area.
Thanks for the help!
[IMG
[IMG
  • floivanus
  • floivanus's Avatar
Re: 82 KZ1100 newb question
06 Dec 2015 20:15 - 06 Dec 2015 20:18
#702223
Needs to be a plug there, that's the oil galley for the motor. Should be able to find one on here. BUT I'm not seeing any threads in there which can definitely be an issue
The bikes with a hose running there is usually for an oil cooler.
Past; 78 kz1000, 83 kz550
Andrew
Last edit: 06 Dec 2015 20:18 by floivanus.
  • Barry2
  • Barry2's Avatar
06 Dec 2015 20:18
#702224
That is supposed to have a plug in it or you will get an oil bath when you start it up. It is also a good place to put an oil pressure gauge if you so desire.
1976 KZ900
  • xxgrizzlybearxx
06 Dec 2015 20:41 - 06 Dec 2015 20:44
#702227
Nice you guys rock. Anyone know the size metric that goes in? I can run down and grab a bolt that'll hold up against that rubber washer. Definitely anxious to get her running and then purring.
EDIT
answered my own question with a search. I believe it's a 14mm.
Last edit: 06 Dec 2015 20:44 by xxgrizzlybearxx.
  • pete greek1
  • pete greek1's Avatar
07 Dec 2015 07:23 - 07 Dec 2015 07:27
#702275
Do yourself a favor, & don't waste your money on a Clymer or Haynes manual, & get a KAWASAKI workshop/service manual, for your specific year & model bike, you wont regret it, there are many for sale on e-bay
Pete
Last edit: 07 Dec 2015 07:27 by pete greek1.
