'81 GPz big rectangular dash change to round gages
- MattM
21 Nov 2015 08:56
Hi,
I have an '81 gpz that I'd like to change that big dash out for some round gages. The speedo appears to be electronic. Can anyone tell me what year and model round gages would interchange? Also, the key currently goes in the panel below the dash that has the odometer in it. I don't really need the odometer and it won't go with the round gages. Can I just replace the key switch with a stand alone? Again, what year and model would work?
thanks, Matt
thanks, Matt
- Nebr_Rex
Re: '81 GPz big rectangular dash change to round gages
21 Nov 2015 16:16
How about pics of the bike and an introduction?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Tyrell Corp
21 Nov 2015 16:32
A clue might be checking out the differences between the GPz1100 B1 and B2 model.
The oversize instrument panel was to deflect windblast, prior to th later model with a fairing. I always think they look quite iconic as in a traditional musclebike style.
- redhawk4
21 Nov 2015 19:40 - 21 Nov 2015 19:46
Which model GPZ do you have? I have a 1981 GPz750 speedo drive in my garage it looks very much like the drive on my KZ1000 and KZ650 other than it's painted black, it would be very easy to hook that up to some older style instruments. As the front wheel would be the same on a GPZ1100 then it seems there would be a way to fit a mechanical drive to that wheel if the 750 had it. A lot of Kawasaki parts will interchange between models, it's usually easiest to find all the bits on a donor bike that you would need to swap over. There are also electronic gauges that are old style available out there. For the old British bikes you can get instruments that look just like the old Smith's gauges but, run from an electronic sensor.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 21 Nov 2015 19:46 by redhawk4.
22 Nov 2015 03:48
The 1981-82 LTD 1000 used round, electronic instruments. They might be an easy fit.
