ZX7/Z1 Oil Cooler
- undiablo
Re: ZX7/Z1 Oil Cooler
02 Dec 2015 13:22
just use a harley old thermostat. I have one since 2013... no problems.
Plenty on ebay and pretty cheap.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
02 Dec 2015 13:24
Got a link?
- redhawk4
02 Dec 2015 14:17
No eBay APP ID and/or Cert ID defined in Kunena configurationI've been watching this one on Ebay if it helps, kind of a name brand.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
03 Dec 2015 05:47 - 03 Dec 2015 05:48
Looks good. Squirted a little paint on it. It's purdy. I may have to get some 90* barb fittings for it so the lines won't be hanging out and I can tuck them under the cooler, along the back bone, then down to the fittings.
Last edit: 03 Dec 2015 05:48 by SWest.
10 Dec 2015 15:07
Being the fittings on the cooler are 3/8" compression and I was able to open up the inlets to 1/2" 3/8" compression/ 1/2" barb don't exist not to mention 90*. So I had to make my own. Used a copper 90* street elbow, crimped the slip side with my flaring tool in a vice, cut a double barb fitting in half and soldered them together. Had to drill out the slag inside and they should work for now.
May look a little funky but they'll work.
11 Dec 2015 15:04
Well got them on. Had to make spacers to get the cooler away from the crash bar and let the clutch cable run where it needs to be. Used 3/8 fuel line and longer bolts. Nice and solid. Put some clear tubing on the inlets to keep dirt out while I get the rest of what I need.
Got some rain. Just enough to dirty up cars. Snow on the mountain though.
11 Dec 2015 17:59
Are you planning to run the lines between headers 2&3, then under the engine?
11 Dec 2015 18:23
No up and over the top along the back bones, then down between 2&3 carbs. The idea is for the oil to stay in the cooler.
11 Dec 2015 18:30
Cool. Would it have been easier to flip the cooler so the lines enter from above?
11 Dec 2015 18:37
That was the plan. Too big and I don't want the lines showing. :whistle:
24 Dec 2015 17:56 - 24 Dec 2015 17:57
Got my fittings but I now have another problem. The fitting size is for a 3/8" line. Too small for the Z1/KZ's. They have to be 13mm/1/2". My old ones were.
I will have to drill and adapt a #8 A/C barb to barb splice cut in half pressed in so I won't have any restriction at the fittings.
The last thing I need is to restrict the oil going to the engine.
Not a happy camper but I suspected it. There's a Alternative Hose place on the way home. I'll pick one up there.
Last edit: 24 Dec 2015 17:57 by SWest.
01 Jan 2016 13:13
Got my hoses run, going to Chaparral for a tire Monday coming back from my daughter's.Alternative Hose is on the way. I'll pick up the fitting then.
I guess I could have gone 3/8" line and fittings but 1/2" is better for oil flow. I didn't think of A/C lines, I might be able to get the sizes I wanted to go to the cooler too.
