Carb mount stripped.
- dom2570
18 Nov 2015 11:22
I noticed the other day that I have a leaking carb boot. I removed the boot and discovered that the threads were stripped.
Would a helicoil do the job or is this a bit more delicate?
Whip it like a mule!
- zed1015
Re: Carb mount stripped.
18 Nov 2015 13:19
Helicoil will do it easily.
- redhawk4
18 Nov 2015 14:44 - 18 Nov 2015 14:46
I took my carbs off today to change the pilot jet size and fit some different float bowls without the accelerator pump. I also had some almost new boots that I swapped for the ones that were on there. Someone had cranked the bolts in pretty tight and I was worried about something breaking, which did cause me to notice there's plenty of metal in that area, should a repair like a helicoil be needed. I also had some stainless steel allen head bolts to replace the unplated ones that were rusting, someone had previously used. The correct fasteners are 6x18mm, on a KZ1000 at least, what bolts were used on yours?. it would seem very hard to strip 15mm or so of thread even with brute force, are the fasteners connecting you boots long enough? there may be good thread you could pick up on with a longer bolt - just a thought.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 18 Nov 2015 14:46 by redhawk4.
- dom2570
Re: Re:Carb mount stripped.
18 Nov 2015 16:40
I believe they were something small like a 6x10
- redhawk4
18 Nov 2015 17:05
It might be worth trying a longer bolt if the holes in the head are deeper. What bike do you have?
1977 KZ650B1
1980 Suzuki SP400
1977 KZ650B1
1980 Suzuki SP400
