Another valve clearance question
- eric951turbo2
15 Nov 2015 18:59
Hey guys, wondering if anyone ever did this....
Doing a new project with my spectre 1983. My engine was pissing oil, and found another clean non leaking engine for 100$ with less miles on it. Told my self it's just cheaper than buying a gasket set.
So I cleaned it all and started checking valve clearance before painting the engine.
All valves where all to specs exept for exhaust #1... At .06mm
So decided to unscrew all camshaft brackets and reinstall them all upon torque specs..... Oooops....
Now all my valves are way too tight, can't even fit my smallest .04mm gauge in neither one of them.
Sooooo.... I was thinking... Instead of buying new shims (trial and errors, cause I can't even measure my clearance now),
COULD I JUST SHIM ALL MY CAMSHAFT BRACKETS WITH VERY THIN WASHERS?
Anyone ever done that?
KZ1100 A2 : In progress
KZ750 Spectre : Ugly but runs
- jackleberry
Re: Another valve clearance question
15 Nov 2015 19:08
That is a terrible idea. You'd be increasing the camshaft bearing clearance. The camshafts would be banging/bouncing around.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- BritGuyUSA
15 Nov 2015 19:19 - 15 Nov 2015 19:25eric951turbo2 wrote: Hey guys, wondering if anyone ever did this....
I'm sure that more than one person has done that before, but you're asking the wrong question. The right question would be "Would that work?'
jackleberry already gave you the right answer to that question.
Are you sure that you are measuring the clearances when the cam is in the right position - i.e. lobe pointing away - 180 degrees - from the shim/bucket?
'75 Z1-B, '78 CB750K8, .79 CBX1000, '85 VF1000R, '94 XR650L, '95 Triumph Speed Triple
Last edit: 15 Nov 2015 19:25 by BritGuyUSA.
- redhawk4
15 Nov 2015 19:27 - 15 Nov 2015 19:36
I agree with jackleberry, but connected with that I'm confused as to how tightening down the bearing caps altered the valve clearances in the first place unless they were already loose and the cam shafts were already floating away from the lower bearing surface. Perhaps I'm misunderstanding what you are saying, but it seems to me there must have been a problem at outset and if all the valves are now tight against the cams, with the caps tightened, it seems that there could likely be a whole host of potential issues with the valves, valve seats, camshafts and camshaft bearings if the motor was run like that before you bought it. Had someone been dismantling the motor before you bought it? At best if the motor was running before with zero valve clearance there is likely to valve damage caused by the valves not seating when the motor gets warm. I feel a new gasket set on your original motor would have been the easier option here, you could be opening up a can of worms. I'd look at at least finding a way to compression test this "new" motor before going further, you could easily be out of the frying pan and into the fire.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 15 Nov 2015 19:36 by redhawk4.
- BritGuyUSA
15 Nov 2015 19:33
I also don't know what the specs are for the exhaust valves on a Spectre, but 0.06 mm is only 0.0024" - which is tight, especially when measuring them in a cold engine.
