High RPM Miss KZ440
  • ajsfirehawk
  • ajsfirehawk's Avatar Topic Author
High RPM Miss KZ440
10 Nov 2015 17:55
#698146
I've got a box stock 1981 KZ440 LTD with only 12K miles on it. It just started exhibiting a new problem. Right at 7K rpm I starts to miss. I really haven't dug into the problem. I did just pull the spark plugs and they look great. The service history is unknown to me. My son and I have driven the bike about 700 or 800 miles without issues until this cropped up. I can't tell if it is spark break up related to coils or bad plugs wires. Also could be a lean condition do to a new issue in the carbs/fuel system. I have not checked the valve clearances and don't know if they have ever been adjusted.
I have pulled, cleaned and lightly lubed the ignition advance mechanism. Last items, the bike does seem to take a long time to warm up, I'd say a full four minutes before it will run off choke. For the first time I also got a backfire when I throttled up to pull into the garage today after a 5 mile ride. Thoughts for what you would go after first?
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: High RPM Miss KZ440
11 Nov 2015 01:34
#698176
ajsfirehawk wrote: Also could be a lean condition do to a new issue in the carbs/fuel system.
Carbs are starting to plug up, time to clean.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
