case
- drewd2385
case
09 Nov 2015 04:55
Ok guys I have a 79 mk II case and was wondering if everything out of that case will swap right over to an 80 kz 1000 case,?
- les holt
Re: case
09 Nov 2015 05:17
Yep, and if you don't mind me asking, something happen to the MK2 cases that deem them unfit?
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- zed1015
Re: case
09 Nov 2015 06:19
If both motors have provision for a kickstart then yes! everything will fit as all kicker motors are basically the same engine with some subtle differences which shouldn't apply if it's just a crankcase swap.
If the later motor was an early 'J' type (which would be 1981 onwards in case you have miss-typed ) with no kickstart then NO it's not a straight swap as these have hyvo type camchain and a different tensioner set up as well as a fatter output shaft and other differences.
- drewd2385
Re: case
09 Nov 2015 07:56zed1015 wrote: If both motors have provision for a kickstart then yes! everything will fit as all kicker motors are basically the same engine with some subtle differences which shouldn't apply if it's just a crankcase swap.
If the later motor was an early 'J' type (which would be 1981 onwards in case you have miss-typed ) with no kickstart then NO it's not a straight swap as these have hyvo type camchain and a different tension:er set up as well as a fatter output shaft and other differences.
Thank you very much for the info it is greatly appreciated and will let u know how it goes thanks again!!
- drewd2385
Re: case
09 Nov 2015 07:58les holt wrote: Yep, and if you don't mind me asking, something happen to the MK2 cases that deem them unfit?
Les Holt
Hi les and no there is nothing wrong with it at all it's just the other case has been bored out to fit a 1197 kit so I am going to buy that if it has a kick start hole on it lol
