New oil leak
- 76KZ900
New oil leak
03 Nov 2015 19:39 - 03 Nov 2015 20:33
In my seemingly never ending quest to rid my 83 1100 from oil leaks a new one has sprung up. Left side of motor sitting on bike where the cases bolt together in the front behind pipes. I've had a number of Kz bikes and never had one leak there. The last one was the o ring in the cam chain tensioner was understandable. The one before that o rings on the oil pressure sending unit was also understandable. But dam now the case ? Anyone have any input on this? Splitting cases to reseal only a pain? I guess I should add that I understand the process but was more wondering when the cases are split what's going to fall out lol Thanks
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 03 Nov 2015 20:33 by 76KZ900.
- pete greek1
Re: New oil leak
04 Nov 2015 06:18
can you post some pics. of exactly where you leak is
Pete
Pete
- 76KZ900
Re: New oil leak
16 Nov 2015 12:59
I cleaned engine again and I guess I was mistaken about source of that leak at case split location. However while riding it yesterday I noticed oil dripping from bottom of motor near clutch cover housing. I noticed drops of oil around primary drive. I DO NOT HAVE PICS as I was using a mechanics mirror to attempt to locate source under bungee. I literally feel like the little boy with his thumb in the dike. As soon as I get one stopped another one starts.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
