Exhaust crossiver pipe fell off prior to initiating patch job
- 750Kruzer
30 Oct 2015 09:43 - 30 Oct 2015 10:56
Had all my supplies laid out. Looked under the bike and there was no "there" there :silly:
goo.gl/photos/KrjdB7XFU5oY38if6
goo.gl/photos/xeqZ2whKZS1kLtYo7
I've read where a couple of people have got the impression that the stock 2- into-2 w/crossover pipe exhaust is superior in performance compared to modern 2- into-1 replacement parts. That's why I was trying to patch rather than replace.
Had previously painted it w/ high temp BBQ paint but that didn't address the underlying issue of corrosion even though I did scrape it prior to painting, the rust was too far gone.
1983 KZ750 LTD Twin K1
Last edit: 30 Oct 2015 10:56 by 750Kruzer.
Re: Exhaust crossiver pipe fell off prior to initiating patch job
30 Oct 2015 10:23
30 Oct 2015 10:38
Here's an inexpensive repair I saw several years ago......
Attachment Repair01.jpg not found
Attachment Repair02.jpg not found
Attachment Repair03.jpg not found
Attachment Repair04.jpg not found
The following user(s) said Thank You: 750Kruzer
- 750Kruzer
30 Oct 2015 10:51 - 30 Oct 2015 10:59
Thanks much Ed. I like the copper pipe solution very much. Gets the job done.
I have seen a cross over pipe replacement for sale but it was for a diff model year. Mine is a 1983 KZ750 LTD K w/ a "B" Code Twin engine. I might be able to buy a length of tube at a local auto supply store as I see they always have pliable replacement muffler tube for sale.
Last edit: 30 Oct 2015 10:59 by 750Kruzer.
- pete greek1
30 Oct 2015 12:14 - 30 Oct 2015 12:18Another option would be to get a length of Stainless Steel Pipe, so you don't have to ever worry about it rusting out, like muffler pipe would, eventually750Kruzer wrote: Thanks much Ed. I like the copper pipe solution very much. Gets the job done.
www.onlinemetals.com/merchant.cfm?pid=96...ches&id=59&top_cat=1
sorry, wrong size came up, but if you look at this place for a 1 inch x 12 inch SS pipe is less than 6.00 dollars
Pete
Last edit: 30 Oct 2015 12:18 by pete greek1.
- 750Kruzer
Re: Re:Exhaust crossiver pipe fell off prior to initiating patch job
03 Nov 2015 10:24 - 03 Nov 2015 10:29
was very fortunate in that i couldnt find a small enough diameter pipe at the local auto part store as they deal in larger diameter exhaust pipes for cars. Went to my local MC shop down the road and they had a generic pipe there. MC mechanic was a real stand up guy and offered to cut it to lemgth and fit it up. Motorcyclists are the best.
Thanks for the tips given here as well
Finished product:
goo.gl/photos/ce9rjZbibEUKTZFV7
Finished product:
Last edit: 03 Nov 2015 10:29 by 750Kruzer.
- pete greek1
04 Nov 2015 06:26Glad you got er done without having to dish out money for a new exhaust750Kruzer wrote: was very fortunate in that i couldnt find a small enough diameter pipe at the local auto part store as they deal in larger diameter exhaust pipes for cars. Went to my local MC shop down the road and they had a generic pipe there. MC mechanic was a real stand up guy and offered to cut it to lemgth and fit it up. Motorcyclists are the best.
Finished product:
Pete
- 750Kruzer
Re: Re:Re:Exhaust crossiver pipe fell off prior to initiating patch job
04 Nov 2015 12:24yes the cbeapest i found was $200+ USD for a complete 2-into-1 systempete greek1 wrote:Glad you got er done without having to dish out money for a new exhaust750Kruzer wrote: was very fortunate in that i couldnt find a small enough diameter pipe at the local auto part store as they deal in larger diameter exhaust pipes for cars. Went to my local MC shop down the road and they had a generic pipe there. MC mechanic was a real stand up guy and offered to cut it to lemgth and fit it up. Motorcyclists are the best.
Finished product:
Pete
