KZ 440 engine starts on left cylinder
  • BornAgainBiker
  • BornAgainBiker's Avatar Topic Author
18 Oct 2015 06:02
#695045
Just got my 1984 KZ 440 ltd running. It starts on the left cylinder and after a bit of warm-up the right cylinder runs, but misses--any thoughts?
All the best, Jeff
1984 KZ440 D6
  • punisher11b
  • punisher11b's Avatar
Re: KZ 440 engine starts on left cylinder
18 Oct 2015 06:46 - 18 Oct 2015 06:51
#695050
Just because it's needs to be ruled out but how are the valves? Have they been adjusted to spec? If they have then I would be looking at the carb, Vacume leaks around the boot to the engine all on the side that is missing. If the boots are original, that would be a red flag.
- good luck
Last edit: 18 Oct 2015 06:51 by punisher11b.
The following user(s) said Thank You: BornAgainBiker
  • BornAgainBiker
18 Oct 2015 07:15
#695052
Thanks for the input. This is a bike that hasn't been running for months and I don't know much about the bike's history as I just bought it. I noticed that the plugs were on the black and sooty side when I pulled them out. I'll take a look at the engine boot, adjust the valves and go from there. Thanks.
All the best, Jeff
1984 KZ440 D6
  • Nebr_Rex
  • Nebr_Rex's Avatar
18 Oct 2015 13:48
#695096
also check the resistance of the plug wire.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
