78 kz650b electric starter won't turn over engine
- blink543
17 Oct 2015 06:47
It seems when the engine is cold and I use the choke the electric starter works fine and starts the engine but when it's warm it barely turns and I have to kick start it.
Adam james
- scubaanders
Re: 78 kz650b electric starter won't turn over engine
17 Oct 2015 07:29
Even a starter motor needs a little love and tenderness.
There are rebuild kits to buy, but it can be a little bit tricky to get it right.
There for it might be smart to check out your local starter/generator service scene.
They are usually familiar with jap starters.
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- blink543
17 Oct 2015 10:03scubaanders wrote: Even a starter motor needs a little love and tenderness.
/A
Why is it tricky?
Adam james
- scubaanders
17 Oct 2015 21:20 - 17 Oct 2015 21:20
No eBay APP ID and/or Cert ID defined in Kunena configurationAssembling it back again and getting the brushes (coal) right require same patience.
If you been tinkering with starters or generators before it's not a big deal, but if it's you first time make sure to have the workshop manual at hand.
Repair kit's are easy to find on Fleebay.
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Last edit: 17 Oct 2015 21:20 by scubaanders.
