When I pulled the Z1R motor apart to change out my twisted crank I found the circlip has dropped off the Shift shaft causing the shaft to wear against the clutch hub. This is the second time this has happened to me.
It appears the circlip groove is not very deep. Has anyone had issues with this previously, if so did you just make the groove deeper?
