Which Lock up for my 1327kz pro street?
  • tomsbadkz
  • tomsbadkz's Avatar Topic Author
05 Oct 2015 10:26 - 05 Oct 2015 10:27
#693452
Attachment 20151005_152704.jpg not found
Attachment 20151005_152714.jpg not found
I have a 77 KZ1000 with a 1327 bottom and a 83-84 GPZ1100 Larry Cavanaugh prepped head. I am going to run a lockup clutch. Would like some feedback on the Differences of these 2 lockups. I have both but undecided. The snowflake is about 8 ounces lighter and is said to be a 2 stage. Would this work for me bike which will be ridden sparingly to have occasional race on track and play on the street. thanks for anyone's help. Tom
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Last edit: 05 Oct 2015 10:27 by tomsbadkz.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: Which Lock up for my 1327kz pro street?
05 Oct 2015 10:40
#693454
I'd go with the lighter of the 2 due to its rotating mass. They work off Trans output speed so in theory it acts like sprung weight, like adding tire and wheel weight. The design of the 2 are basically the same as in function is the same, between clutch spring preload and lever weight you have 2 stages of lockup is the idea behind it.
Hth
Les holt
  • racer54
  • racer54's Avatar
05 Oct 2015 11:54
#693463
They are both called lock-ups, work the same and you adjust them the same. Some call them (both) a two-stage (because you can adjust the static spring pressure and the weight on the arms for different reactions on where it affects the run), but they are your basic lock-ups. There is a multi-stage lock-up but it looks different and although it works on same principle it is more adjustable then these two. And also more expensive. I like the snowflake for same reasons Les says. Less rotating wieght. Or you can get a MTC Gen11 clutch. They are awesome and only cost about $2500!
The following user(s) said Thank You: PLUMMEN
  • tomsbadkz
05 Oct 2015 12:13
#693466
I see that on the bottom of the bosses where the spring seat is, the snowflake has a shoulder machined and the round lockup doesnt. i have been told to use stock springs as to not have too much spring pressure cause the lockup will increase with speed. so, stay with stock springs?
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
05 Oct 2015 13:54
#693486
I've seen stock, old worn or weak stock and H2 spings. If you not trying to bust off some low 60' times, go with stock and no weights, smoothest transition. Lite springs and heavy weights, hard transition, balancing act is what your after and each bike/rider/track is different. play with it, just adds to seat time.
Les
  • zukdave
  • zukdave's Avatar
05 Oct 2015 16:11
#693507
Only diff. is the snowflake is cut out more then the disk type
and the snowflake has retainer screws for the arm pins and not just peened in
but they'll do the same thing.
Lots of way's to set one up just depends on how you want to ride the bike
First thing is put a good clutch pack and spring's in it to start with and see if you need the lock up.
If it's gonna slip the clutch it'll be the top of 4th or 5th gear.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • zed1015
  • zed1015's Avatar
  • Online
05 Oct 2015 23:44
#693536
For the road either will do the job.
The snowflake is a two stage and the other one is single stage .
The shoulders on the two stages spring boss's allow the springs preload to be altered by way of shims (washers) so you can increase or decrease the amount of clutch on the 60 foot.
To keep things simple use the single stage to reduce clutch slip when on the power.
The two stage will need a little experimentation with springs and shims to get the right balance of slip and grip off the line for a perfect launch.
  • tomsbadkz
07 Oct 2015 01:51
#693627
I think im going to use the snowflake lockup because i think its what will work for my setup. I really appreciate the advice that you guys give. This forum has been such a help with my slow moving project. The Round lockup is for sale. $50.00 shipped in the U.S. Let me know by forum or pm. The disc on the right of the pic is the one for sale. Tom
Attachment 20151005_152714-2.jpg not found
Attachment 20151005_152704-2.jpg not found
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • Hollywoodmx
  • Hollywoodmx's Avatar
Re: Re:Which Lock up for my 1327kz pro street?
09 Oct 2015 06:36
#693923
les holt wrote: I've seen stock, old worn or weak stock and H2 spings. If you not trying to bust off some low 60' times, go with stock and no weights, smoothest transition. Lite springs and heavy weights, hard transition, balancing act is what your after and each bike/rider/track is different. play with it, just adds to seat time.
Les
My bike came with a snow flake off the bike in the parts bin. You guys told me what it was last time and I forgot. What does it do again and how is it installed?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
