84 KZ440 speedo ratio
  • Bobbed440
  • Bobbed440's Avatar Topic Author
04 Oct 2015 10:07
#693286
Hey guys I have a 84 KZ440 bobber I'm putting a new speedo on and need to know the speedo ratio so I get the proper one
  • martin_csr
  • martin_csr's Avatar
Re: 84 KZ440 speedo ratio
04 Oct 2015 12:15 - 05 Oct 2015 03:11
#693303
The stock speedometer is probably the 2240 type (2240 revs = 1 mile). I think that's a Japanese standard. You'll probably need to get an aftermarket speedo with the ratio typically listed as 2240@60mph. I didn't see an 84 model in the diagrams at partzilla, but the speedo drive gearbox at the wheel on the 83 440 Ltd has a 26T speedometer gear & 9T pinion, which is fairly common for KZs along w the 2240 stuff.
Last edit: 05 Oct 2015 03:11 by martin_csr.
The following user(s) said Thank You: Yoshi
