- Thank you received: 540
Any engine rebuilding, top ends etc. ZDDP
- z1kzonly
01 Oct 2015 10:44 - 01 Oct 2015 10:45 #692843
by z1kzonly
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
Any engine rebuilding, top ends etc. ZDDP was created by z1kzonly
- bountyhunter
- Thank you received: 337
01 Oct 2015 13:50 #692861
by bountyhunter
Replied by bountyhunter on topic Any engine rebuilding, top ends etc. ZDDP
No eBay APP ID and/or Cert ID defined in Kunena configurationExcept it washes off and leaves basically nothing:
I use this stuff:
It raises the Zinc levels to what they are supposed to be (about 1500 ppm)
ZPasteā¢ helps here as well, when applied at approximately 1 gram per lobe and fully dissolved in the oil, it will contribute a useful 65 ppm of phosphorus in the form of ZDDP to 5 quarts of oil.
I use this stuff:
- bountyhunter
01 Oct 2015 14:00 - 01 Oct 2015 14:03 #692865
by bountyhunter
A cheap way to get zinc levels back up in oil is to use STP oil treatment:
forums.vintage-mustang.com/general-discu...p-oil-treatment.html
but it is about 90W so diluted in 4 quarts of oil it will bump your viscosity about 5 points so if you put in 10-40 you will end up with 15-45 which is OK to run.
Last edit: 01 Oct 2015 14:03 by bountyhunter.
