Firing Order KZ1000P-9
- yorkieUK
01 Oct 2015 06:27
Can anyone confirm if I've got my firing order right please.
Attachment ignitioncoils.gif not found
1982 GPZ1100 plunger chop
1990 KZ1000P-9 (ex San Diego P.D.)
- jackleberry
Re: Firing Order KZ1000P-9
01 Oct 2015 06:53
Left coil fires 1 & 4, right coil fires 2 & 3.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
The following user(s) said Thank You: yorkieUK
- Grnole
01 Oct 2015 06:58
yea that picture looks to have the coils reversed... unless your wiring is back-asswords
1980 KZ1000 LTD -B4
1984 Yamaha FJ1100
1972 Honda CL350 (sold)
1984 Yamaha FJ1100
- yorkieUK
01 Oct 2015 07:07
Thanks for the reply.
Thought I should check first because the image on CMS website makes it look like it's the other way around.
Just to confirm, is this right?
Attachment ignitioncoils2.gif not found
- jackleberry
01 Oct 2015 07:10yorkieUK wrote: Thanks for the reply.
Well, now the numbers are right at least.
To clear things up, in case this is where the confusion lies, it doesn't matter at all which wire from the left coil goes to #1 and which goes to #4, just that they do. They fire simultaneously.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- yorkieUK
01 Oct 2015 07:16
To clear things up, in case this is where the confusion lies, it doesn't matter at all which wire from the left coil goes to #1 and which goes to #4, just that they do. They fire simultaneously.[/quote]
Thanks for the info, I just learnt something new. :woohoo:
- jackleberry
01 Oct 2015 07:24 - 01 Oct 2015 07:25yorkieUK wrote: Well, now the numbers are right at least.
Thanks for the info, I just learnt something new. :woohoo:[/quote]
The reason is that these bikes use what is called 'wasted spark' ignition. So when the coil for 1 & 4 fires, one cylinder is on the power stroke and the other is on the exhaust stroke (and this is the spark that's wasted).
Otherwise they'd need 4 coils (or 1 coil and a distributor).
The only real down side is that, unlike on a car with a distributor, when you pull a plug wire, you don't just kill that cylinder, you also kill the other cylinder attached to that coil. Something to keep in mind when troubleshooting...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
Last edit: 01 Oct 2015 07:25 by jackleberry.
