1979 KZ650 D2 Service Manual
- thetallwhiteguy86
28 Sep 2015 14:41
I'm trying to find a service a manual for a 1979 KZ650 D2. I had to take apart the engine to knock a piston loose that was seized. I need to know how to set the cam chain timing. Any help will be appreciated. Thank you in advance.
- thetallwhiteguy86
Re: 1979 KZ650 D2 Service Manual
28 Sep 2015 14:46
Is Clymer a proper service manual for this bike. The title is "1977-1983 Kawasaki KZ650D SR Repair Manual Clymer M358 Service Shop Garage:"
28 Sep 2015 17:02 - 28 Sep 2015 17:04
I wouldn't bother with the Clymer or Haynes manuals. The Kawasaki Service Manuals that include the 1979 KZ650-D2 can be identified by their part numbers. Both "99924-1007-02" and ""99924-1007-03" include the US model KZ650-D2. The list of models can be seen on the back cover - be sure to check that it covers your specific model. The front cover has a green KZ650 on it as shown below. Be sure to get the correct one since there are big differences between the various KZ650 years & models. Ed
Attachment 00003a-119.jpg not found
Attachment 00003b-35.jpg not found
Last edit: 28 Sep 2015 17:04 by 650ed.
- thetallwhiteguy86
30 Sep 2015 06:05 - 30 Sep 2015 06:06
There may be others, but this one is reasonably priced.
KAWASAKI KZ650 MOTORCYCLE SERVICE MANUAL
eebbaayy item # 262022267567
Last edit: 30 Sep 2015 06:06 by martin_csr.
30 Sep 2015 08:23 - 30 Sep 2015 08:24martin_csr wrote: There may be others, but this one is reasonably priced.
BE CAREFUL. Take a look at the back cover of the manual in that eBay listing. It shows the KZ650-D2 is "OTHER THAN US MODEL". I don't know what the differences are, but if your bike is a US model that manual may not cover everything exactly the same (possibly such as wiring diagrams). I would try to get a manual with one of the two part numbers I listed above since they specify the D2 US model on the back cover. Ed
Last edit: 30 Sep 2015 08:24 by 650ed.
02 Oct 2015 05:05
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's one of the correct manuals. It just now popped up on eBay. Ed
