NGK B8ES or NGK BR8ES
  • yorkieUK
  • yorkieUK's Avatar Topic Author
28 Sep 2015 10:32 - 28 Sep 2015 10:36
#692324
What is the difference between the B8ES & BR8ES?
Does anyone run their KZ1000P on NGK Iridium plugs or Brisk Premium LGS plugs?
Attachment p1.jpg not found
Attachment brisk.jpg not found
1982 GPZ1100 plunger chop
1990 KZ1000P-9 (ex San Diego P.D.)
Last edit: 28 Sep 2015 10:36 by yorkieUK.
Re: NGK B8ES or NGK BR8ES
28 Sep 2015 10:49
#692328
The "R" in "BR8ES" stands for resistor. You bike doesn't need resistor plugs, and if it has resistor spark plug caps using R plugs may cause a problem. Ed
The following user(s) said Thank You: yorkieUK
  • yorkieUK
28 Sep 2015 10:51
#692329
Thanks Ed.
650ed wrote: The "R" in "BR8ES" stands for resistor. You bike doesn't need resistor plugs, and if it has resistor spark plug caps using R plugs may cause a problem. Ed
  • Puffin
  • Puffin's Avatar
28 Sep 2015 13:09
#692353
Yorkie you can run your Zed on the Brisk plugs. Good quality and cheap, i no longer use other manufactures :)
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
  • pete greek1
  • pete greek1's Avatar
28 Sep 2015 13:34
#692358
Puffin wrote: Yorkie you can run your Zed on the Brisk plugs. Good quality and cheap, i no longer use other manufactures :)
how do you figure cheap, at 17.99 each plug ??
Pete
28 Sep 2015 13:51
#692359
$17.99 each! Holy cow! I use the specified ND plugs and have never have any problems with them; a set very easily lasts more than 10,000 miles. A few years ago I bought 4 packs of 10 (40 spark plugs) from eBay for $12 with free delivery! That's enough plugs to last beyond my lifetime. :laugh: I would look at using the specified ND or NGK plugs since they work perfectly fine. Ed
Attachment 00003a-118.jpg not found
The following user(s) said Thank You: conghos
  • pete greek1
28 Sep 2015 15:59
#692391
650ed wrote: $17.99 each! Holy cow! I use the specified ND plugs and have never have any problems with them; a set very easily lasts more than 10,000 miles. A few years ago I bought 4 packs of 10 (40 spark plugs) from eBay for $12 with free delivery! That's enough plugs to last beyond my lifetime. :laugh: I would look at using the specified ND or NGK plugs since they work perfectly fine. Ed
I agree, & I feel like I get better performance from the NDs then the NGKs
Pete
  • Wyliecoyote
  • Wyliecoyote's Avatar
29 Sep 2015 16:04 - 29 Sep 2015 16:07
#692552
where can u get the nd plugs?
Last edit: 29 Sep 2015 16:07 by Wyliecoyote. Reason: Spelling
29 Sep 2015 16:17 - 29 Sep 2015 16:19
#692553
ND is the name that was adopted by Nippondenso years ago. They now just use the name Denso. If you look in your Kawasaki Service Manual you will see they recommend either ND spark plugs or NGK spark plugs. The manual for your specific bike will show exactly which plugs to use. I have used both brands and found the ND plugs work best in my bike. My KZ650-C1 uses ND W22ES-U plugs. Those are the "Hot-U" plugs with the "U" shaped ground electrode. Different KZ engines use different model plugs, so check the manual for the correct ones for your bike.
Many places sell them. Check online or local bike shops. You might even find a great deal on eBay. Ed
Last edit: 29 Sep 2015 16:19 by 650ed.
  • pete greek1
30 Sep 2015 08:21
#692609
Wyliecoyote wrote: where can u get the nd plugs?
The Auto Zone by me sells them, try there
Pete
  • pete greek1
30 Sep 2015 08:58 - 30 Sep 2015 08:58
#692616
Any engine that takes the NGK B8ES plugs also take the ND W22ES-U plugs
my 1980 LTD 1000 uses the same plugs as 650ed's KZ 650
Pete
Last edit: 30 Sep 2015 08:58 by pete greek1.
30 Sep 2015 09:35
#692621
pete greek1 wrote: Any engine that takes the NGK B8ES plugs also take the ND W22ES-U plugs
Pete
There may be a bit of confusion on this one.
The NGK B8ES plugs are the same heat range as the ND W24ES-U plugs. These plugs are one heat range colder than the plugs below.
The NGK B7ES plugs are the same heat range as the ND W22ES-U plugs.
