550 block / crankcase O rings Viton
- Tyrell Corp
20 Sep 2015 07:26
Anyone know what size these are? I'm getting 10mm ID 11mm OD from the oil jet but don't have any O rings to measure.
Are the bigger oval O rings, cylinder head to block available in Viton? (the ones that look like a slightly elongated capital O, rather than a lower case o )
Attachment dyty.jpg not found
- ydb1
Re: 550 block / crankcase O rings Viton
26 Oct 2015 07:42
Partzilla says 9.8mm. 670D2010 O RING
Not sure what the cross section is. That would make it easy to find a viton part. The o-ring store: www.theoringstore.com/index.php?main_pag...fo&products_id=22954
'81 GPz550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
past rides:
93 GSX1100G
01 ZRX1200
84 GS1150E
80 KZ550
The following user(s) said Thank You: Tyrell Corp
- Tyrell Corp
26 Oct 2015 07:59
I ordered kawasaki genuine parts, that 0.2mm could have caused problems thanks anyway.
