Can't find a gasket for a KZ400
  • PDogg
  • PDogg's Avatar Topic Author
16 Sep 2015 09:03
#690316
I'm having trouble finding a valve cover gasket for a 1974 KZ 400. I'm in the middle of an engine rebuild, and progress has stalled as a result. I've checked eBay, Google, and Amazon. Unfortunately, I don't know of any good local parts dealers for motorcycles, either (Colorado Springs area), Does anyone have any advice? I've attached an image of what I'm looking for from KZ400.com.
Re: Can't find a gasket for a KZ400
16 Sep 2015 09:35 - 16 Sep 2015 09:43
#690324
If you are looking for #9 in the diagram below see:
www.ebay.com/dsc/i.html?_sop=10&_dmd=1&L...28ford%2Cbilstein%29
If you are looking for #29 in the diagram there is no gasket; Kawasaki used sealer. Ed
Attachment 00003a-104.jpg not found
Last edit: 16 Sep 2015 09:43 by 650ed.
The following user(s) said Thank You: PDogg
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
16 Sep 2015 09:40 - 16 Sep 2015 09:41
#690325
Search Google, Ebay, etc using the part number not the description. If the number superceeded, use all new numbers too.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 16 Sep 2015 09:41 by Kidkawie.
  • PDogg
16 Sep 2015 13:18 - 16 Sep 2015 13:19
#690354
650ed wrote: If you are looking for #9 in the diagram below see:
That's exactly what I needed to know. Thanks!
Last edit: 16 Sep 2015 13:19 by PDogg.
