78 400 crankshaft
- Drafter89
78 400 crankshaft
12 Sep 2015 04:44
Would anybody know what cranks I could swap out with my stock one. I have this 78 400 c model and the crank is shot. I can't find any info on it. I found this kz440 motor that looks almost identical to mine only difference is the cam chain tensioner. And I was told the crank is still good in it.
78 KZ 400 C1-Daily Driver
New Albany,IN
New Albany,IN
Re: 78 400 crankshaft
12 Sep 2015 05:15
The KZ400 and KZ440 cranks are different part numbers. Ed
- Drafter89
12 Sep 2015 05:24
So I just have toto find one wih the same part number!? Correct?
New Albany,IN
New Albany,IN
- Online
12 Sep 2015 05:31 - 12 Sep 2015 05:35
Sometimes you can interchange parts between models but swapping a crank is not typically that simple. Hopefully there are some twin experts that can chime in but I think you would be better off looking for a 400 crank or a new engine.
Edit: just checked ebay and there are quite a few KZ400 cranks for sale for cheap.
Last edit: 12 Sep 2015 05:35 by Nessism.
12 Sep 2015 05:32
If you find one with the same part number it will be a direct swap. I don't know why the KZ440 crank has a different part number than the KZ400, but it may be that the ends of the cranks are different. The image below shows a comparison of photos I found on the internet. I don't know how accurate they are, but it looks like the crank ends may differ. Ed
Attachment 00003b-30.jpg not found
12 Sep 2015 05:41
Note: from the diagrams at Partzilla there appear to be at least 2 different crankshaft part numbers for the KZ400, Their cross-reference isn't 100% accurate so be sure to double-check the diagrams for each model.
12 Sep 2015 05:41
There's the deal breaker.
- Nebr_Rex
12 Sep 2015 17:08
The '78/79 KZ400 is a hybrid engine. It still has a roller chain in the new
style cases (KZ440). The 440 has a hyvo chain (link plate).
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- diggerdanh
15 Sep 2015 10:04
Can you use the whole 440 motor? Or at least what there is of it?
