1982 kz750 csr twin. needs starter clutch/flywheel
- greedsdesire
11 Sep 2015 11:21 - 11 Sep 2015 11:21
My 82 kz 750 twin has been having electric start issues. I've got it taken apart and pulled the rotor bolt off. Just trying to figure out the exact puller I need to pop the rotor and clutch off the flywheel so I can fix it. If anyone can help me out here that would be awesome so I can get it back together and going
Thanks
Thanks
Last edit: 11 Sep 2015 11:21 by greedsdesire.
- bountyhunter
Re: 1982 kz750 csr twin. needs starter clutch/flywheel
11 Sep 2015 19:59 - 11 Sep 2015 20:08
I thought the flywheel needed a good whack to come loose from the shaft? Been a lot of years since I pulled mine. Here are the manual pages on the starter clutch.
Last edit: 11 Sep 2015 20:08 by bountyhunter.
- greedsdesire
12 Sep 2015 05:26
Awesome thanks so much! Which book is this from? I guess I have the wrong manual cause it doesn't have this section in it. Anyway I could get a copy of the whole manual?
- bountyhunter
12 Sep 2015 23:18
It's the factory service manual. I got one on a CD off ebay for $5. May be one posted somewhere.
