1981 j 1000 with 1981 1100 jugs
  • harleeblue
  • harleeblue's Avatar Topic Author
07 Sep 2015 15:41
#689050
Buying the mtc piston 1135 12:5:1 on a 1981 1000j bottom end with Andrew 3x cams what head would best work with my combo and what year? I don't know if I should look for a 1983 84 1100 head or use the 1981 1100 head. Or just use my j head ? Looking for somebody to point me in the right direction
bradley frantz
  • Puffin
  • Puffin's Avatar
Re: 1981 j 1000 with 1981 1100 jugs
08 Sep 2015 02:10
#689094
Use your head and send it off to Larry Cavanaugh www.cavanaughracing.com/
He is a member on here but might be better to conatact him direct, as he seems not to be answering pm`s here at the moment
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
  • zed1015
  • zed1015's Avatar
08 Sep 2015 03:59
#689107
Use the earlier plain hemisphere 1100 or the 'J' head if you want a straight forward assembly.
The later bathtub (twin swirl) head as used on the gpz unitrack and later 1100's has slightly steeper valve angles which may cause valve to piston crown clearance issues and will involve claying the pistons and possible machining of the valve pockets to get the correct clearances.
The following user(s) said Thank You: Tyrell Corp
