Is this acceptable?
- Turbo99397
Is this acceptable?
05 Sep 2015 09:53
I bought this bike as is... kz1000 1980, idk what's stock n what's not. I don't get much time to work on it as my dad is Ill and I have been visiting him alot. I have some time this weekend finally and I noticed there's a piece of oversized hose from one side of the valve cover to the other. It's leaking for sure, pulling vacuum. If I pull it completely off it pops like crazy from the exhaust. If I plug them with my fingers for a min it stops. It's got stupid pod filters and Iv been fighting that, and my center 2 cyls going dead. Could this be related? Can they be just capped? If not what do I need to do.... I wish I could find a stock airbox for this thing....
Attachment 20150905_123351.jpg not found
Re: Is this acceptable?
05 Sep 2015 10:21
That is very common. All you need is a hose that fits well. It is not causing your dead cylinders problem.
www.kzrider.com/forum/2-engine/599546-clean-air-system-delete
Cylinders 2 & 3 are fired by the same coil, so the coil may be bad or there could be a bad connection to it, or the secondary wires may be cracked and broken.
- GPzMOD750
05 Sep 2015 10:26TexasKZ wrote: That is very common. All you need is a hose that fits well. It is not causing your dead cylinders problem.
+1
I just capped them. check for leaky carb boots, good compression and make sure your valves are properly adjusted.
- Turbo99397
05 Sep 2015 10:57
Could I just clamp the hose, it's leaking badly, or get a better fitting hose? I'm assuming this would cause some running issues pulling vacuum... no?
- pete greek1
05 Sep 2015 11:00
That hose looks short & there is no hose clamps to keep it from leaking
if your spark plug wires are long enough, you can try switching the wires from 2 & 3, with 1 & 4, & see if the problem moves to 1 & 4, but first get a proper size hose & clamps for the reed valves on the valve cover
Pete
Pete
- Kwaker2000
05 Sep 2015 15:19
get some ape block of plates for the reed valves ,and plug the carbs except for the one that goes to the petrol tank vacuum port
Attachment WP_005477-2.jpg not found
- pete greek1
05 Sep 2015 15:41
50.00 + $$ for Ape block off plates, about 2.00, for rubber hose & clamps
Pete
Pete
06 Sep 2015 00:23
:woohoo:
- GPzMOD750
06 Sep 2015 07:18
I'd tack some beer can material or aluminum sheet, trace it out, cut it and put them under the caps for good measure.
- GPzMOD750
06 Sep 2015 08:18Does it have to be beer? :laugh:swest wrote: I'd tack some beer can material or aluminum sheet, trace it out, cut it and put them under the caps for good measure.
06 Sep 2015 08:24
Coke if you'd like. :lol: I have some aluminum stock that is used for roofing repair. I also have heavier gauge sheet stock. You can get some at HD, Lowes etc.
