Kickstarter stuck
  • Drafter89
  • Drafter89's Avatar Topic Author
Kickstarter stuck
04 Sep 2015 18:00
#688683
Recently had this motor apart because the balancer settings weren't right. Got all of that taken care of and put back together..no more vibration, fired right up and rode it down the street no problems whatsoever and was going through the gears smoothly. All of the sudden bike just died. Fixed that problem. Was just a loose connection but when I went to start it back up the kickstarter wouldn't budge. When I had the clutch lever pulled in it would turn but that's it. So I disassembled the clutch cover and the whole right side of the engine and I put everything back together right so I'm stuck. Any ideas?
78 KZ 400 C1-Daily Driver
New Albany,IN
  • KZFrankenstein
  • KZFrankenstein's Avatar
Re: Kickstarter stuck
16 Sep 2015 07:17
#690309
If you put the bike in gear, say 3rd, and roll it so the engine turns over, does it budge?
Does the kickstarter move at all after that?
Projects:
1979 Kawasaki KZ750 (almost rider)
1982 Yamaha MJ50 (in progress)
198- Yamaha QT50 (x2) (not started)
1971 Honda CB350 (finished show bike)
1970 Honda CL350 (not started)
