KZ 1000 MK 11
- gtrain
KZ 1000 MK 11
31 Aug 2015 03:36
Hay can everybody tell me if a KZ 1000 MK 11 seat will fit a 1979 Z 1000 ST?
- pete greek1
Re: KZ 1000 MK 11
31 Aug 2015 09:38
I believe that it should, I think the only difference between an MK II & an ST, is that the MK II is chain drive & an ST is shaft drive
Pete
Pete
- RonKZ650
Re: KZ 1000 MK 11
31 Aug 2015 20:35
Not even close. Sorry. No bodywork from the MKII will interchange with the ST. Everything on the ST is larger. May look the same in pictures, but no, no way to use the parts between the two.
I have both.
I have both.
The following user(s) said Thank You: pete greek1
- pete greek1
Re: KZ 1000 MK 11
01 Sep 2015 08:55
Thanks for chiming in, Ron, I never knew, as I've never seen one side by side
pictures are deceiving
red one is an ST, and the blue one is an MK II
moto.zombdrive.com/images/kawasaki-z1000-st-1980-8.jpg
www.redlinecycle.com/Mvc-041J%20RH%20alt.JPG
Pete
Pete
- bassie10
Re: KZ 1000 MK 11
01 Sep 2015 10:03 - 01 Sep 2015 10:21
I have seen a few of both, and I think the dimensions of the seat itself are the same, the hinges and stuff under the seat are at different places..
Last edit: 01 Sep 2015 10:21 by bassie10.
- RonKZ650
Re: KZ 1000 MK 11
01 Sep 2015 21:28
The seats look the same, but not even close. The ST is much wider, the whole ST is a big motorcycle for its time, where the MKII was more or less normal size. I love both of them, but if you have one, don't expect to swap any parts if you buy the other. All bodywork including guages, all suspension, fenders, all different on the ST, Air intake different. They used up man hours beyond comprehension when the ST came out to make every part different and unique to the model and never used again.
Re: KZ 1000 MK 11
01 Sep 2015 21:34
Another engineer strikes again.
- bassie10
Re: KZ 1000 MK 11
02 Sep 2015 04:02 - 02 Sep 2015 04:05
Left top: aftermarket MK2 right top: another aftermarket MK2
left bottom: aftermarket ST right bottom: original ST
Yep, both ST's are a little short of an inch wider..
Attachment DSC_03471.jpg not found
Last edit: 02 Sep 2015 04:05 by bassie10.
- gtrain
Re: KZ 1000 MK 11
04 Sep 2015 11:15 - 04 Sep 2015 11:18
Thanks for the info about the difference in the seats
my seat pan is rusted out, so I'am chasing a good replacement.
Where can I get one of those aftermarket seats from?
Last edit: 04 Sep 2015 11:18 by gtrain.
