82 KZ 1100 shaft Spitting during warm up
- LTD Rider
26 Aug 2015 20:04
Hi Guys
New here and getting back at cycling after a 25 year hiatus. I have an 1100 with 23,000 miles that likes to spit and sputter till it is warmed up. Are these bikes jetted lean from the factory for the 80's emissions? I have done all the usual stuff, like plugs, wires, made sure carbs were clean etc. The needle on carb 4 was out of place, causing midrange stumbling, but this has been corrected.
thanks Ed
thanks Ed
- DGA
Re: 82 KZ 1100 shaft Spitting during warm up
26 Aug 2015 22:56
My '83 1100 shaft was lean, it has 37.5 pilot jets stock, and even with the idle screws set at 3.25 turns out it's still lean, takes a lot of choke to run from cold. I have bought 40s for it that I think will fix that. I also added shims under the slide needles and that gave the midrange a lot better pull. Make sure you don't have any vacuum leaks also.
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
- GPz550D1
27 Aug 2015 05:30 - 27 Aug 2015 05:32
Bought a KZ1100 shaft drive new in '82 and it did the same thing as yours, was jetted very lean. First thing done to it was to shim the jet needle up with one small washer and that helped it to run perfect through all rpm ranges, hot or cold. Only got 35-40 mpg with that bike, but it was a blast, until hitting a deer on the highway.
1981 KZ550-D1
Last edit: 27 Aug 2015 05:32 by GPz550D1.
