Starting Issue
- Muskrat
Starting Issue
24 Aug 2015 19:23
After minor engine rebuild (mostly cleanup plus honed, new rings, cleaned carbs), The engine started right up with choke on but was running horrible. #1 cylinder erratic if firing at all. Checked carbs again, all jets clean as are idle needles. Now bike wont start at all unless I shoot a few shots of gas straight down carb throats. Tried with choke, without choke, with throole closed, part open, etc. Am I missing something obvious that changed overnight?
- rstnick
Re: Starting Issue
27 Aug 2015 20:11
Take the spark plugs out to let the cylinders air out.
Maybe you've flooded it.
Once aired out, start from scratch:
Key on, Kill on, cutch in, in neutral, fuel valve to prime if it has, or ON position.
Choke up all the way.
NO throttle.
Hit the start button and hope she starts.
NO throttle.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: Muskrat
- jackleberry
Re: Starting Issue
27 Aug 2015 20:44Muskrat wrote: After minor engine rebuild (mostly cleanup plus honed, new rings, cleaned carbs), The engine started right up with choke on but was running horrible. #1 cylinder erratic if firing at all. Checked carbs again, all jets clean as are idle needles. Now bike wont start at all unless I shoot a few shots of gas straight down carb throats. Tried with choke, without choke, with throole closed, part open, etc. Am I missing something obvious that changed overnight?
What bike is it? Obvious things are coil wires swapped and cam timing being off.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
