Engine Pegs Out
- Lazyman06
Re: Re:Engine Pegs Out
28 Aug 2015 06:24
To clarify. When you say it revs up and bounces. Is the engine free revving like you have the clutch in or on neutral, or, does it act like someone stuck a grapefruit in the tailpipe
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
- txfirewarrior
Re: Re:Re:Engine Pegs Out
28 Aug 2015 06:31Definitely not like the clutch is in because the engine doesn't rev up. So I guess like someone stuck a grapefruit in the tailpipe. I don't have a tach so I don't know RPMs, but for example, it's like it hits 4000 RPMs and stops there. Won't go higher even if I twist the throttle just "bounces".Lazyman06 wrote: To clarify. When you say it revs up and bounces. Is the engine free revving like you have the clutch in or on neutral, or, does it act like someone stuck a grapefruit in the tailpipe
Sorry, I know this is probably pretty amateur description but this is my first bike and first time going through any of this.
1978 KZ400-C1
- txfirewarrior
Re: Engine Pegs Out
28 Aug 2015 08:00 - 28 Aug 2015 11:27swest wrote: Pics of the bike first. I want to see what kind of carbs you have and the overall condition.
Oh and welcome.
Here are some pics of the bike! The carb pics aren't the best, I don't know why I didn't take the covers off before taking the pics!
1978 KZ400-C1
Last edit: 28 Aug 2015 11:27 by txfirewarrior. Reason: Photos were removed from photobucket and had to relink them.
- missionkz
Re: Engine Pegs Out
28 Aug 2015 17:28
The pod air filters on those carburetors and the color of those exhaust pipes ought to be telling you what's wrong.....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- txfirewarrior
Re: Engine Pegs Out
28 Aug 2015 17:40missionkz wrote: The pod air filters on those carburetors and the color of those exhaust pipes ought to be telling you what's wrong.....
Well the exhaust was that color before I got it, and the carbs were tuned great for the first 100 miles I drove it. I know they can cause issues, but the PO had rebuilt both carbs and tuned them to match the pods.
Like others have said, I am wondering now if it is fact a fuel issue, probably because of ethanol gasoline. Boy this stuff sucks. What a terrible idea.
1978 KZ400-C1
- missionkz
Re: Engine Pegs Out
28 Aug 2015 21:39Then I think he screwed up the carb rebuilds and the bike is too lean.txfirewarrior wrote:missionkz wrote: The pod air filters on those carburetors and the color of those exhaust pipes ought to be telling you what's wrong.....
Let's see the spark plugs.
Float level could be too low on both carbs and or your fuel selector is becoming plugged and can't fill the bowls fast enough. Etc.
Bruce
1977 KZ1000A1
1977 KZ1000A1
