Kz440 crank pin
- dom2570
Kz440 crank pin
20 Aug 2015 20:48
When the engine seized up on my 440, the pin at the end of the crank broke off due to me being a dumbass. I have found a few used cranks on ebay for around $50, but also found replacement pins on partzillia for like $1.50.
Is there an easy way to replace the pin or would it be simpler to just put a new crank assembly in?
part 92043 is the one that broke.
www.partzilla.com/parts/search/Kawasaki/...-D3-D4-D5/parts.html
Whip it like a mule!
- dom2570
Re: Re:Kz440 crank pin
21 Aug 2015 05:48
Take it to a machinist. He will remove it in just a couple minutes and it shouldn't cost much to do. Ed
