Mystery Bolt (750E)
Mystery Bolt (750E)
11 Aug 2015 17:58 - 11 Aug 2015 18:01
Can't figure out where this goes. I'm going through the entire engine and found these (2 of them) in the parts washer. Hex size is 12mm. Any suggestions?
Last edit: 11 Aug 2015 18:01 by Nessism.
Re: Mystery Bolt (750E)
11 Aug 2015 18:28
Could they be the 8X43 cylinder head bolts that are used in the cam chain tunnel? Ed
- GPz550D1
Last edit: 11 Aug 2015 18:33 by GPz550D1.
11 Aug 2015 18:33650ed wrote: Could they be the 8X43 cylinder head bolts that are used in the cam chain tunnel? Ed
Think you nailed it Ed! Thanks! That sounds right!
- DFIGPZ
12 Aug 2015 14:15
they are the head bolts under cam cover I always helicoil the holes and use high strength allen bolts as a replacement.
1984 750 Turbo
