Sprocket Info
  • 5.0liter
  • 5.0liter's Avatar Topic Author
Sprocket Info
08 Aug 2015 12:22
#684930
Does anyone know what sprocket fits the front of a KZ motor to change to a 530 sprocket? Thanks.
  • pete greek1
  • pete greek1's Avatar
Re: Sprocket Info
08 Aug 2015 13:11
#684936
If you change the front sprocket to a 530, you also have to change the rear sprocket to a 530, & you have to get a 530 chain
Z1 Enterprize can set you up with what you need, give them a call & tell them what you want to do
Pete
The following user(s) said Thank You: PLUMMEN
  • GPzMOD750
  • GPzMOD750's Avatar
Re: Sprocket Info
08 Aug 2015 20:50 - 08 Aug 2015 20:50
#685015
Last edit: 08 Aug 2015 20:50 by GPzMOD750.
  • 5.0liter
Re: Sprocket Info
09 Aug 2015 07:07
#685051
Thanks for the info. I'm building a dragbike and want to change to a 530 setup so I can setup my gearing.
  • martin_csr
  • martin_csr's Avatar
