Compression
  • Zapzuta
  • Zapzuta's Avatar Topic Author
Compression
05 Aug 2015 15:51
#684508
What should the compression be at on a 76 Kz 900 with the 1075 kit
  • missionkz
  • missionkz's Avatar
Re: Compression
05 Aug 2015 17:13
#684524
That totally depends on the Pistons used and the way they are built. Just over boring a few millimeters doesn't automatically change the compression ratio unless the Pistons are built to do so or not build to do so.
My 1075 kit is 10.25:1
Others can be what ever the manufacturer specifys.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: Compression
05 Aug 2015 18:41
#684536
Are you after the compression ratio, or the expected value on a compression test?
1981 KZ750 LTD
