Subaru 32mm Valve Shims
05 Aug 2015 10:14 - 05 Aug 2015 10:20 #684447 by pbmax
Subaru 32mm Valve Shims was created by pbmax
No eBay APP ID and/or Cert ID defined in Kunena configurationI just discovered that the Subaru Impreza and Legacy use 32mm over bucket valve shims. Thickness range from 2.00 to 2.81.
Anyone try these in your KZ750?
opposedforces.com/parts/impreza/us_g11/t...nism/illustration_1/
Last edit: 05 Aug 2015 10:20 by pbmax.
05 Aug 2015 10:28 #684449 by pbmax
Replied by pbmax on topic Subaru 32mm Valve Shims
Searching Subaru forums, they are supposed to be 32mm.
But even if they fit correctly, is there anything else to be worried about such as hardness?
  • SWest
  • 10 22 2014
05 Aug 2015 12:05 #684476 by SWest
Replied by SWest on topic Subaru 32mm Valve Shims
I wouldn't think so. The shop in town has some 29mm shims for VW. They are much thicker than ours so not usable.
05 Aug 2015 12:10 #684481 by pbmax
These Subaru 32mm shims have thickness from 2.00 to 2.81.
KZ 32mm shims have thickness from 2.20 to 3.4.
These **could** work. Maybe, hopefully, pretty please...
05 Aug 2015 14:28 #684498 by bountyhunter
Replied by bountyhunter on topic Subaru 32mm Valve Shims
pbmax wrote: These Subaru 32mm shims have thickness from 2.00 to 2.81.
I would say the hardness would be the question. The Kawi shims are surface hardened to a very hard value, not sure exactly what Rc value but really hard. If usable, that is a great find. The thinner values are the most needed since most old heads have been "seated" a few times and the valve is deeper in the head.
10 Aug 2015 17:20 - 10 Aug 2015 17:23 #685292 by pbmax
I ordered a Subaru 32mm shim. Pics below comparing 1 Subaru shim to 3 KZ 32mm shims.
My valve cover is back on so I didn't try it my KZ750 B4, but looks like it would work.
Last edit: 10 Aug 2015 17:23 by pbmax.
10 Aug 2015 18:38 #685303 by mike1957
Replied by mike1957 on topic Subaru 32mm Valve Shims
I wish you luck with it let us know how it works out.
I would stay with Kawasaki oem parts.
mike1957
  • SWest
  • 10 22 2014
10 Aug 2015 19:03 #685307 by SWest
I haven't had any problems with aftermarket shims. If these are factory they should be just as good if not better.
10 Aug 2015 19:23 #685311 by Nessism
10 Aug 2015 19:48 #685316 by mike1957
I've had my experiences with after market parts,not shims but
other parts.Thinking I was going to save some money. on my kz 1000 and 900 anyway it was not worth
buying them.Had to get the oem parts the after market parts were crap and had to do the job again.
a lot of time and money wasted.I rather spend a little more on the parts and do the job once.
mike1957
10 Aug 2015 20:47 #685326 by Nessism
Replied by Nessism on topic Subaru 32mm Valve Shims
mike1957 wrote: I've had my experiences with after market parts,not shims but
Do whatever you want, but I expect Subaru parts to be at least as good or better than Kawasaki parts. It's the crappy K:&L aftermarket parts that I worry about.
