KZ400 Cylinder Boring
  • Hwmetzger
  • Hwmetzger's Avatar Topic Author
27 Jul 2015 22:19 - 27 Jul 2015 22:21
#683081
I had a 1976 KZ400 given to me, the catch being the engine is seized. After pulling the head the cause was pretty apparent.... Thankfully I have a Bridgeport mill and I'm not afraid to tackle the boring job.
My question is, will I need a different head gasket to match the oversized pistons and rings? I'm not sure if there's such a thing as an oversized head gasket, but I'd thought I would ask before I started!
My other option is buying a decent cylinder block on ebay. Any chance a 440 cylinder and head would fit my early 400 bottom end?
Last edit: 27 Jul 2015 22:21 by Hwmetzger.
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: KZ400 Cylinder Boring
27 Jul 2015 22:45
#683083
I'm no expert, but this old thread here says that you can't fit a 440 head onto a 400 unless it's a 1978-1980 KZ400.
On head gaskets, I'm less experienced with motorbikes, but I'm pretty sure it applies to both cars and bikes. Unless you're going for a big bore, the standard head gasket will be fine. Head gaskets usually have a fair amount of clearance from the cylinder walls anyway. Have a look at your old gasket - if your rebore brings it out further than that, you might need a custom gasket (unless they do sell overbore head gaskets for these, overbore gaskets do exist).
1981 KZ750 LTD
  • diggerdanh
  • diggerdanh's Avatar
28 Jul 2015 07:48
#683113
Neither the later 400 (78+) nor the 440 top end will fit the early KZ400 bottom end (74-77). Not sure about the headgasket. Have you already obtained the oversize 400 pistons and rings? If not, they are pretty hard to find and if you do find them they are usually pretty expensive, but you might get lucky on Ebay.
You may end up spending much less getting another early engine to replace the existing or better yet upgrading to a later 400 or 440. But if you're set on overboring and refreshing the current one for the challenge then I'll definitely be along for the ride.
  • davido
  • davido's Avatar
28 Jul 2015 09:18
#683120
Its also maybe worth looking into a 500/550 top end. If youre going to do all the work anyway,why not go for a bit more umph!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Tyrell Corp
  • Tyrell Corp's Avatar
28 Jul 2015 10:00
#683125
Head gaskets are usually slightly oversize, I assume to allow for 1st and 2nd oversize up to 1mm. As long as the bore is no bigger than the gasket internal bore then you should be ok I think. Alternatively, cometic make oversize head gaskets.
You might get lucky and find a pair of NOS oversize pistons on ebay, alternatively depending upon the pin size you might be able to find oversize pistons rom something else, bearing in mind piston shape, compression and minimum cylinder wall thickness.
28 Jul 2015 10:23 - 28 Jul 2015 10:24
#683130
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • Nessism
  • Nessism's Avatar
  • Away
28 Jul 2015 11:06
#683140
Just want to mention that boring with a mill is one thing but honing is completely different. Don't think you can do a proper honing job without a proper honing machine.
  • Tyrell Corp
28 Jul 2015 12:47
#683152
I have on of those three legged drill mounted honing tools. I'm not sure if it really is up to the job. I usually hone used bores but I might not bother in futre.
It seems piston rings, break in and cylinder honing is a controversial subject, for the most commonly used engineering design since the industrial revolution.
  • Hwmetzger
28 Jul 2015 13:58
#683162
I've been watching for a 440 or later 400 engine to pop up for sale but for about 2 months without any luck. And yeah, I'm aware about honing the cylinders and whatnot, I just mentioned boring em' because I don't think a hone is going to clean these up.
I don't have the oversize pistons or rings yet, but after looking around it may be cost effective to wait for another engine to come by. These early 400's are an expensive adventure it seems!
