Engine knocking
25 Jul 2015 19:07 - 25 Jul 2015 19:11 #682734 by Drafter89
Engine knocking was created by Drafter89
Just picked up this 77 kz400 today for 300 bucks and as I'm driving the antique home on the highway it just completely lost its power. I had the throttle wide open and it didn't respond..just acted like it wanted to die. I made it to the next exit and pulled off. Let it sit for a minute and cool off and tried to start it and the the kick starter barely wanted to move. I checked the little oil bubble and there was only a tiny bit of oil in the engine. :( I got it started but after cruising in 2nd gear on the way home the engine started knocking.. bad!!! Got it home safely, still fires up and seems to have good compression but why did all this happen you think?
Oh..and this bike has pods and the exhaust is cut down to collector pipe if that helps. And it's has been re jetted for those mods
78 KZ 400 C1-Daily Driver
New Albany,IN
Last edit: 25 Jul 2015 19:11 by Drafter89.
25 Jul 2015 20:33 #682745 by TexasKZ
Replied by TexasKZ on topic Engine knocking
If the bike was really that low on oil, could be a trashed bearing (crank, rod, cam, transmission, some combination), could be piston slap, but I'd put money on one of the bearings. Running an engine out of oil at freeway speed is one of the worst things that could be done to it.
You can drain what is left into a clean container, along with the filter, and look carefully for shiny bits. If they are present, you likely have a serious, expensive problem. The only way to know for sure how bad the damage is, is to carefully disassemble the engine with your factory service manual and some good measuring tools at hand.
The following user(s) said Thank You: Drafter89
25 Jul 2015 21:08 #682757 by 650ed
Replied by 650ed on topic Engine knocking
+1
No or very low oil will kill an engine very quickly. :( Ed
26 Jul 2015 06:06 #682774 by Drafter89
Replied by Drafter89 on topic Engine knocking
Drained the oil. Only a thimble full was in it. I should of checked before I put it on the road. :( but oil is clean! Now on to disassembling the engine I guess :angry:
New Albany,IN
  • SWest
  • 10 22 2014
26 Jul 2015 06:41 #682778 by SWest
26 Jul 2015 06:43 - 26 Jul 2015 06:45 #682779 by Drafter89
That's what was in the filter
sorry for the pic quality but I wiped those shards of metal on the towel there
New Albany,IN
Last edit: 26 Jul 2015 06:45 by Drafter89.
  • SWest
  • 10 22 2014
26 Jul 2015 06:52 #682784 by SWest
26 Jul 2015 07:01 - 26 Jul 2015 07:01 #682786 by Drafter89
swest wrote: So you didn't fill it?
No. The guy I bought it from lives about 10 min away so I didn't bother with checking the oil. I just hopped on it and left.
Learned my lesson
New Albany,IN
Last edit: 26 Jul 2015 07:01 by Drafter89.
  • SWest
  • 10 22 2014
26 Jul 2015 07:13 #682788 by SWest
Replied by SWest on topic Engine knocking
WTF :ohmy:
I changed my oil on my Chevy one time, was putting in the oil but forgot to put in the drain plug. Lost three quarts before I checked it. Distracted by a low life again wanting beer. I'm now really good at throwing tools. All I have to do is pick up a wrench and give them that look. :evil:
On my own again. :woohoo:
I can hit a moving target at 300' with my rigging ax. :whistle:
26 Jul 2015 10:30 - 26 Jul 2015 10:32 #682815 by missionkz
Replied by missionkz on topic Engine knocking
I had a KZ400 for a while... nice little ride.
Does the crankshaft use plain bearings for rod and mains?
If yes.... OUCH X 100.
If no, you might have dodged a bullet on a major overhaul but if seized, your piston skirts will most likely be trashed and the cylinders will be scored like a MOFO. You'll probably be looking at a top end rebuild. Hopefully the cam bearing areas are OK.
I've seized my share of two stroke engines!!
A little acid in the cylinders to eat off piston skirt aluminum, a cheap honing tool from the local auto parts to clean/re cross hatch the bore and and a new piston with rings made them run like new again.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 26 Jul 2015 10:32 by missionkz.
27 Jul 2015 05:37 - 27 Jul 2015 05:38 #682931 by Drafter89
I lucked out on this one!! filled it with fresh oil and it runs fine. :)
Thank god!
New Albany,IN
Last edit: 27 Jul 2015 05:38 by Drafter89.
27 Jul 2015 05:39 #682933 by Drafter89
Something is telling me to get in there and look around though because I did find a lot of metal bits in my oil filter :sick: so I must have done something internally.
New Albany,IN
