kickstart issue
  • codymknutson14
  • codymknutson14's Avatar Topic Author
kickstart issue
20 Jul 2015 16:49
#681881
Recently my kickstart wont engage on my 1976 kz400, when i push down on it it no longer turns the pistons or anything, does anyone have any imput that can help me out??
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kickstart issue
20 Jul 2015 17:30
#681883
Is that all you've been using?
Re: kickstart issue
20 Jul 2015 17:58
#681894
You aren't pulling in the clutch lever, are you? Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kickstart issue
20 Jul 2015 18:00
#681895
:woohoo: Probably a broken spring from over use.
  • TexasKZ
  • TexasKZ's Avatar
Re: kickstart issue
20 Jul 2015 21:23
#681921
Many of the early KZ 400s were kickstart only.
There are several things that can go wrong, and the only way to know for certain is to take it apart. PLEASE be sure you have a factory service manual on hand. The mechanism is a bit more complicated than you might imagine and it is easy to to put it back together incorrectly.
