1981 Kz650 head questions
- Tyrell Corp
Re: 1981 Kz650 head questions
06 Aug 2015 18:36
All looks pretty normal to me, burning hydrocarbons gives heat, Co2 .water and a load of other stuff, some of that staying in the combustion chambers and manifolds.
I'd be more interested in a side pic of the pistons, is there much evidence of oil burning below the rings - or maybe looking at the colour of the exhaust valves and plugs.
Carb cleaner is good for cleaning this, and mayve a wooden (no scratch) scraper. Note recent safey warning posted here on carb cleaner and eye protection, I always knew it was nasty stuff.
- zukdave
06 Aug 2015 18:59 - 06 Aug 2015 19:00
After reading this I'll say this Just find a ZX750A1/A2 motor and and be done.
Bone stock it's like 25 hp stronger and with some goodie's my 810 motor's making mid 90's.
with stock ZX750A1 cam's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 06 Aug 2015 19:00 by zukdave.
- jeffo
Re: Re:1981 Kz650 head questions
06 Aug 2015 19:13If my head works with the 750 block and the carbs will work with a stage 3 then I am only out the $75 for the block and pistons. Of course I need a seal kit. I got a new cam chain and guides already (actually bought them in 2009). And I was planning in doing some head work and cleanup myself. An engine on ebay is $499-$599 + freight. I am looking for a good running bike with some pick up but I don't need to go crazy. Maybe if I find a cheap pair of 750 cams I can throw them in as well....zukdave wrote: After reading this I'll say this Just find a ZX750A1/A2 motor and and be done.
1981 KZ650H1 CSR
- jeffo
06 Aug 2015 19:15
Side of the piston looks fine to me.
1981 KZ650H1 CSR
- 650mod
07 Aug 2015 17:42
My pistons after 30k miles. You're looking fine.
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- jeffo
07 Aug 2015 19:55
Yeah. I didn't think there was an issue. I need a new cam chain and guides and thought I would do the rest while it's all torn down. I think I caused the cam chain issue many years ago by tightening a manual chain tensioner to much. There are groves in the guides and I had a lot of noise after that. The chain actually looks fine but I decided to tear it down and replace the seals, chain, and guides. Prior to me my best friends dad bought this bike new. He rode it to work all the time for many years and kept good care of it. As a kid growing up I helped with many oil changes.
1981 KZ650H1 CSR
- jeffo
07 Aug 2015 19:59
When I say no issue I was not sure on the build up in the head. I knew the Pistons and engine were good though.
1981 KZ650H1 CSR
- 650mod
08 Aug 2015 05:42
I don't know if you've had any luck with splitting the head yet, but make sure you check the valve faces to see if they're worn. Mine were worn so badly that there were grooves in them, not seating properly/at all. The valves had to he refaced and then the head had to be shimmed. Just something to keep in mind
78 kz 650 custom
- jeffo
08 Aug 2015 16:44
I have not split the head yet. I would assume that just means pulling the valves. Sorry not up to all the lingo yet. I was going to see if this was possible with a big c clamp I have I guess some people are successful. If they look OK I will probably just clean everything up. I saw somewhere you can get the 750 intake valves and use them on the 650 head. I will look into that if valves are needed.
1981 KZ650H1 CSR
08 Aug 2015 18:30
Be careful. The KZ650 intake valves are a different part number than those used on the KZ750. Ed
- jeffo
08 Aug 2015 21:47 - 08 Aug 2015 21:48
I thought I saw someone that did the 750 block with the 650 head.
www.kzrider.com/forum/2-engine/559505-kz...l=component&type=raw
Looks like it was a success. I will upload a bunch of photos of my 750 block and pistons when it comes. I want to see if there appears to be any issues before moving forward. The block I purchased is from a 1983 Kawasaki KZ750N. The only thing I will have to figure out if its in good shape is how to remove the paint.
1981 KZ650H1 CSR
Last edit: 08 Aug 2015 21:48 by jeffo.
- jeffo
08 Aug 2015 21:49
No eBay APP ID and/or Cert ID defined in Kunena configuration the listing has some photos. Everything looks pretty good to me...
1981 KZ650H1 CSR
