Location of oil pressure sensor on 1984 GPZ 1100?
- jackleberry
17 Jul 2015 12:47
It seems that the oil cooler fitting on this bike lacks a port for the oil pressure sensor. Where does it go?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- etbike3135
Re: Location of oil pressure sensor on 1984 GPZ 1100?
17 Jul 2015 15:47
its in the oil pan
1973 Kawasaki Z1
18 years in dragbikes
- jackleberry
17 Jul 2015 16:17etbike3135 wrote: its in the oil pan
OK, thanks.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- DFIGPZ
17 Jul 2015 22:02
1983 / 84 GPZ1100 does not have a oil pressure sender the one in pan is a level indicator.
1984 750 Turbo
18 Jul 2015 06:46 - 18 Jul 2015 06:48
In the diagrams at Kawasaki.com the oil level switch is listed in the Breather-cover/oil-pan diagram.
The oil level switch is bigger than an oil pressure switch & it has a 25mm o-ring.
1984 ZX1100-A2 GPZ
27010-1067 SWITCH,OIL LEVEL
671E2525 O RING,25MM
1984 ZX1100-A2 GPZ
Last edit: 18 Jul 2015 06:48 by martin_csr.
