tach leaking oil
  • blink543
  • blink543's Avatar Topic Author
tach leaking oil
30 Jun 2015 22:40
#678906
So my tach on my kz650 has been dripping oil on the pipes it's annoying. Which seal do I replace? I replaced the one that goes on the outside inside the assembly. Not the o ring. And it's still leaking so what's causing this?
Adam james
Re: tach leaking oil
01 Jul 2015 04:33
#678914
No eBay APP ID and/or Cert ID defined in Kunena configurationThat is a common leak. When mine leaked there I replaced the parts listed below. That was 8 years ago and it has not leaked since. I believe you can still get them at the local or online Kawasaki parts dealers or maybe new old stock on eBay, or you can buy the aftermarket kit at
(13) 92055-1149
(14) 92087-010
(15) 92050-075
(16) 92065-103
Attachment 00003a-51.jpg not found
  • martin_csr
  • martin_csr's Avatar
01 Jul 2015 05:57 - 01 Jul 2015 06:02
#678930
For anyone who hasn't done the tach seal before & if you're new to this stuff:
On another Kaw forum someone recently broke his cylinder head where the bolt threads in.
So use a good penetrant & give it time to work, before trying to remove the tach holder bolt.
Kroil is supposed to be best. I use LiquidWrench penetrating spray lubricant ---- it's readily available & cheap & it works.
pb blaster didn't do as good in a test that's floating around the internet. wd40 isn't a penetrant.
Last edit: 01 Jul 2015 06:02 by martin_csr.
01 Jul 2015 06:10 - 01 Jul 2015 06:22
#678933
martin_csr wrote: . . . someone recently broke his cylinder head where the bolt threads in. . . .
For example, see thread:
www.kzrider.com/forum/2-engine/598548-kz...k-fork-broken#676370
which includes the following:
Patton wrote: . . .
blink543 wrote:
Good Fortune! :)
Last edit: 01 Jul 2015 06:22 by Patton.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jul 2015 08:53
#678950
and be sure to use a JIS screwdriver bit NOT a Phillips. If you need a description of JIS (Japanese Industrial Standard) bit just ask; you can easily make your own in just a couple minutes. DO NOT tackle that screw with a Phillips or you will just round it out. Ed
