Reed valve covers
  • Lazyman06
  • Lazyman06's Avatar Topic Author
Reed valve covers
25 Jun 2015 11:19
#678218
Took the reed valve cover off to see the condition of the reeds and they apparently bought autozone out of they're rtv silicone. Also I thought there was supposed to be a vent nipple coming off of these. Will this hurt the bike if the valve cover can't vent?
Attachment 0619152130.jpg not found
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
  • Lazyman06
Re: Reed valve covers
25 Jun 2015 11:20 - 25 Jun 2015 11:21
#678219
cover
(edit: apparently the cover picture won't post)
Last edit: 25 Jun 2015 11:21 by Lazyman06.
  • jeff80kz1000e2
  • jeff80kz1000e2's Avatar
25 Jun 2015 11:56
#678223
Nope, most guys cap them with an aftermarket or home made cover. APE I believe makes one you can buy. I had the original with the nipple on them and cut the hose short that was attached to the nipple and plugged it with a bolt and a hose clamp ( cant see it with the tank on and cost much less than the covers unless you nake them yourself ) .
The CAS ( clean air system ) was an epa regulation back in the day if I am not mistaken and the bike does just fine with it removed.
  • davido
  • davido's Avatar
25 Jun 2015 12:01
#678224
A simple idea I heard was to just run the hose twixt one cover and t'other.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Lazyman06
Re: Re:Reed valve covers
25 Jun 2015 13:16
#678237
Here's the kicker mine doesn't have a nipple at all and I don't see ape etched on the top
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Jun 2015 13:19
#678239
Are they open? Nah, can't be.
  • pete greek1
  • pete greek1's Avatar
25 Jun 2015 13:30
#678245
Are you saying that's the cover, with the 2 square holes in it ?? ..& they weren't plugged up ?
Pete
  • pete greek1
25 Jun 2015 13:31
#678248
This is what I did with my covers
Pete
Attachment DSCF1624-2.jpg not found
  • pete greek1
25 Jun 2015 14:09
#678252
No eBay APP ID and/or Cert ID defined in Kunena configurationBuy these & connect the hose to each other, or your bike will not run right with those holes in the breather caps
Pete
  • davido
  • davido's Avatar
25 Jun 2015 15:00
#678259
Lazyman06 wrote: Here's the kicker mine doesn't have a nipple at all and I don't see ape etched on the top
I Think only the American models had the breathers. For environmental controls.Something to do with sending the partially unburnt exhaust gases back into the airbox to be reused!? European models didnt have this and Just came with closed plates. If theyve not got APE stamped on them theyre probably original equipment.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Lazyman06
25 Jun 2015 15:38
#678269
Kinda odd and kinda cool at the same time that it isn't an american engine. is it safe to say I can go with out the air valve assembly. Im gonna be running pods anyway
Attachment E1130.png not found
  • 80B4
  • 80B4's Avatar
25 Jun 2015 16:15
#678273
The reed valves allow oxygen to enter the exhaust port so that any unburned fuel is consumed. BMW used that same system design to get their twins to pass the emissions tests.
1980B4 1000
1978 Z1R
1978 B3 750
