Clutch Fitment
- bvallerand
Clutch Fitment
23 Jun 2015 10:08
I have a 1976 KZ750B1. I am trying to replace the clutch plates but I am seeing some confusing inconsistencies with information from different manufacturers/retailers.
According to z1 the clutch plates for the KZ750B1 and the KZ750G are the same...which makes sense seeing as they are both 750 twins.
The EBC catalog doesn't list fitment for the KZ750B at all. But they do list fitment for the KZ750G. For the 750G they list CK4435 as the part number for a stock replacement cork clutch plate set. They list the same part number for the KZ750K as well. From what I can find the 750K is also a twin.
The list of other bikes that use the same part number clutch plates is quite long. Since I am having trouble finding a performance clutch plate for the kz750B is it safe to assume that plates for a 750G will fit/work?
1976 Kawasaki Kz750
- bvallerand
Re: Clutch Fitment
24 Jun 2015 06:20
Nobody knows?
Does anybody know the difference between the 750b and 750g?
1976 Kawasaki Kz750
- 80B4
Re: Clutch Fitment
24 Jun 2015 06:41
Yes the part number for the is the same for the KZ750B1 and the KZ750G so the EBC plates will work. The G model has different wheels, seat, handlebars and fenders. The engines are 95% the same, the carbs and charging system are different from your B1.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- bvallerand
Re: Clutch Fitment
24 Jun 2015 07:02
Ok. Thanks for the help. That's what I was thinking. Was the g sold in america? I tried looking up oem part numbers for it directly from kawasaki and from bike bandit and neither of them list it as an option.
1976 Kawasaki Kz750
- 80B4
Re: Clutch Fitment
24 Jun 2015 07:12
Yes it was sold here in the US and is listed as "KZ750-G1 LTDII. The best prices I've found for OEM parts are these folks.
www.metricpartsoutlet.com/index.htm
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- bvallerand
Re: Clutch Fitment
24 Jun 2015 09:23
Good to know and thanks for the parts source.
The clutch on my bike slips if I drop a gear and yank the throttle. I run Castrol 20w50 motorcycle oil (non-synthetic). As time goes the slipping gets worse. I pulled the plates out and they are all within spec but some of them have concentrated wear spots (they are not all even all the way around). They all measure ~3mm (within spec) but on some of the wear spots they measure a small as 2.8mm. I know this is still within spec but given the fact that the clutch has been slipping and the plates have not worn totally even I am still thinking I should replace them.
The cable is adjusted properly so I know that is not the source of the slipping and it still slips even after a fresh oil change.
I still need to test the springs for proper tension but now I am looking for opinions...
I have read that some people swear by the stock replacement cork friction plates. The bike is heavy (as are all 750 twins) and I weigh 250lbs so I am thinking an upgraded clutch may be a good idea. I also occasionally ride with a passenger so this doesn't help the weight.
I am considering the EBC SRC46 www.amazon.com/EBC-Brakes-SRC46-Street-Clutch/dp/B006O71VTM
Has anyone had any experience with it?
I am a bit wary of going with a HD spring since the clutch pull on the bike is already quite stiff.
Opinions? Experiences?
1976 Kawasaki Kz750
- zukdave
Re: Clutch Fitment
24 Jun 2015 09:46
APE Track king clutch is as close to OEM as you can get
and at $63.00 it's hard to beat.
Also all the KZ fours use the same clutch so get the KZ1000
replacement friction's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZB2 650
Re: Clutch Fitment
24 Jun 2015 10:04 - 24 Jun 2015 10:13
Hard to beat the NOS Kawasaki plates and I've always run Barnett HD springs....... they along with EBC springs are only a 10% increase in pressure so I really don't think there is a whole lot of difference in the lever feel ...... I just replaced my worn out ones and hardly felt the difference at all ......some add a washer to new stock springs but I like the idea of going with the HD ones instead.
Check out Partzilla ........ 13088-040 plates are only 6.63 each .....are listed for the 1976 KZ750B1......... My KZ650 and the 1000s list 13088-030 plates needed and are 12.33 each........
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 24 Jun 2015 10:13 by KZB2 650.
- bvallerand
Re: Clutch Fitment
24 Jun 2015 10:50
Awesome guys. Thanks for the input. I decided to go with the EBC cork replacements and EBC springs. Got all of it from Amazon for $64 with prime shipping so they will be here by Friday...I love prime shipping.
1976 Kawasaki Kz750
- 80B4
Re: Clutch Fitment
24 Jun 2015 18:45
Make sure you service the clutch perch and clutch release. I disassemble mine every spring and inspect the pivot bolt and the pivot bore in the lever. If either shows much ware I replace them, The clutch release (the mechanism located down by the counter shaft sprocket ) almost never needs replacing but always works better if it is clean and lubed. I use a good waterproof grease when I assemble it. Inspect the cable and lube it too and your good to go.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
